Hi martin,sad to say when i last looked,this went biss enc.
hi sid thanks for info
i took the plunge with the azbox
i am finding it hard to get my head round but i think it is/will become a great box if the updates keep coming through
i have started to find other forums with more help to the dark side of this box not got anywhere at the moment but very willing to learn
if you find any sheffield games would be good i am new to this but enjoying it thanks
martin
martin
Hi martin,if i see any sheffield games i post em for you m8.On azbox got 1 west open,but other thing i asked & got no help.Been very p*ssed 0ff over this,but thats life m8.today @ 7pm there was not 1 feed posted on that board,shot em-selfs in the foot with me now.Im a much better feedhunter than william 1 wil ever be.He only got the section when i fell out with em.
hi sid
i must agree i only asked questions on the general set up and very slow on answers
atm i am just trying to get tps installed for scanning and finding my way round the box
if i get anywhere on the dark side i will pm you with info/links
martin
hi sid
martin
Transponder side if you need any help just give me a shout m8
martin on satellites your use for feeds m8 wipe out the transponders in the box & add your own.This is a tip from me m8 that i think helps.from setting then into tv channel,press okright side arrow then ok.Down to sat/tp edit & hit ok.Here you can add remove what you wish m8.
hi sid thanks
i am shouting
atm i am only scanning on 10.0E and 7.0E
is there a list of tp to input for the uk i have been on satellweb and most of the tp there is no signal i have found a few that are picking things up thanks
a couple of more questions if you could help please
when adding a tp you get a choice of
modulation with 3 different options does this matter which on i choose and plot 0/1 same question thanks
martin
hi lads got a satalite and box yesterday.only have 100 channels on it.its a triax sr110.is thear firmware to get more channels or codes or freqencies or sumting that i can get more channels.its pointing at astra.do i need to move this to get more/any info would be great.or do i need a better box?
hi sid thanks
i am shouting
martin
red as it says on transponder to remove,green to add new tp m8.Now on modulation you need to change,if it says a feed is in s2.with side arrow next to ok button change to what the feed is transmitted in.Also your need to add the right fec with s2 feeds or no signel will show m8.
What satellite receiver do you have m8?ps ok its a triax sr110,i dont have this receiver sorry,cant help,maybe someone else here has one.
