Satellite Feeds
  • martin-f
    • 535
    #106
    also is ths a feed sid
    10.0 E 12679 H 6666
    MB HD 5 #1
    it must have been it gone now
    • satsid
      • Aug 2009
      • 815
      #107
      Originally posted by martin-f
      thanks sid
      so as for fec i would need to put 3/4 etc other than 6111 etc thanks for your help
      martin
      6111 for sr most times will be mpeg2 so auto fec will be ok.Its s2 mpeg4 that you need right things,or you azbox wont pick up the transponder.Some times your also need to change the pilot to 1 with s2 mpeg4
      • satsid
        • Aug 2009
        • 815
        #108
        10.0 E 12679 H 6666
        MB HD 5 #1
        thats a feed m8,soon as i saw 6666 for sr i knew.
        ps this feed is a sleep atm,so your get no signel atm.
        • dinnycoakley
          • 20
          #109
          sorry for interfearing lads thanks anyway.
          • satsid
            • Aug 2009
            • 815
            #110
            for sheff martin,always look on this transponder on 13e.
            id teleippica
            10723h 29900
            saterday thay show a game from championship m8.
            ps its pot luck what match
            • martin-f
              • 535
              #111
              thanks sid so the best thing to i would say for me is add the tp then goto tv channel advanced scan ok then alter modulation and pilot untill i see a signal would that be right thanks again
              martin
              • satsid
                • Aug 2009
                • 815
                #112
                no bother m8,i just wished i could have helped.Your not interfearing @tall m8.
                • satsid
                  • Aug 2009
                  • 815
                  #113
                  martin
                  Yes your right on that m8,thats one way.Your find life more easy if you get rid of most transponders on 10 east first,then just add new transponders.
                  Your pay tv sats dont change the transponders in your azbox.ie 13 east 19e or 1 west.
                  • satsid
                    • Aug 2009
                    • 815
                    #114
                    Martin when footie is over i give some tp to add m8
                    • satsid
                      • Aug 2009
                      • 815
                      #115
                      must be another beach ball for liverpool
                      ps 2-1 Lyon
                      • martin-f
                        • 535
                        #116
                        thanks sid
                        where can i find a list for tps for feeds please
                        your a mind reader thanks sid
                        • satsid
                          • Aug 2009
                          • 815
                          #117
                          martin scan this in all mode(enc) m8 into your azbox.
                          10e
                          11306v 29998 5/6
                          dvb-s2/8psk
                          pilot 1
                          This feed years back was on 12 west.sometimes it shows stuff from USA.Service 3 your see a test card onit atm.
                          ps let me know when you have this feed in your azbox
                          • martin-f
                            • 535
                            #118
                            just doing it now sid check pm
                            • satsid
                              • Aug 2009
                              • 815
                              #119
                              10997v 6666 7/8 if you add this now its on @ 10e martin.
                              ps be quick,its a feed for zdf
                              • satsid
                                • Aug 2009
                                • 815
                                #120
                                just gone a sleep this one,other feed will be fine.
