Initial EPG problems turned worse....!
  • Techdope
    • Jan 2016
    • 22
    2. Most of my epg doesnt populate until I actually go into the channel, I think I've followed the settings correctly. Is there something I should look at??
    Amended this post as I appear to have fixed some of the problems, still having the EPG probs tho..... !!!
  • martin035
    • Apr 2014
    • 1308
    1. What box are you using?
    2. What image are you using?
    3. What EPG plugin are you using?
    • Techdope
      • Jan 2016
      • 22
      Im using a zgemma2s, Ive flashed Mtpockets image (latest update). Im not sure on the plug-in as it was all set up within the image, xmltv perhaps????
      • martin035
        • Apr 2014
        • 1308
        Mt's image uses xmltvupdater, as I use Crossepg I'm unsure of how to setup xmltvimporter, sorry
        • Techdope
          • Jan 2016
          • 22
          No worries, cheers anyway
          • happy_highlander
            • Aug 2010
            • 3535
            Xmltv requires frequent updating of the rytec xml file as it only scans the frequencies listed in the xml file do when a channel changes it doesn't always have the new frequency to scan. Best of installing crossepg 0.6.2 (svn 300) and enable astra 28.2
            • Techdope
              • Jan 2016
              • 22
              Thanks Highlander, could you advise on how to do that please???!! Sorry I'm a real newbie to all this
              • happy_highlander
                • Aug 2010
                • 3535
                Download this file enigma2-plugin-systemplugins-crossepg_0.6.2-svn-300-r0_mipsel.zip and extract it then ftp .ipk file to tmp on box using dcc and install then reboot, then go to menu>setup>crossepg>configure and set it to download to your usb/hdd/storage device and force epg to reload on boot=yes, update daily at around 0530 or about 15 mins after your autobouquet updates then go to opentv providers and enable astra 28.2 only save it and download.
                Job done cross epg will fully populate epg evry morning at your specified time.
                • martin035
                  • Apr 2014
                  • 1308
                  As you've flashed images before it might just be easier to flash this image and follow the instructions in the thread, your goes in the same place and as Mt's
                  As Many members know, I updated to a H series Zgemma a while back, but DK member 'madness85' has an original Zgemma S and has developed his image for use by others on the forum, this image will work on a Zgemma S or 2S Openatv5.3 Backup Image with New improved SkyQ Skin, OTA update safe * AutoBuoquetsMaker autoupdate daily
                  • Techdope
                    • Jan 2016
                    • 22
                    Originally posted by happy_highlander
                    Download this file [ATTACH]354976[/ATTACH] and extract it then ftp .ipk file to tmp on box using dcc and install then reboot, then go to menu>setup>crossepg>configure and set it to download to your usb/hdd/storage device and force epg to reload on boot=yes, update daily at around 0530 or about 15 mins after your autobouquet updates then go to opentv providers and enable astra 28.2 only save it and download.
                    Cheers Highlander, but that did have me scratching my head I'm afraid..!!!! I'll try Martins image.
                    • Techdope
                      • Jan 2016
                      • 22
                      http://www.digital-kaos.co.uk/forums...proved-ky-Skin
                      Cheers Martin. This is going to sound super stupid but I cant find the file to download on the linked thread....!!!! Can you point me in right direction please???
                      • happy_highlander
                        • Aug 2010
                        • 3535
                        That would have been my first suggestion had you not asked how to install crossepg
                        • Techdope
                          • Jan 2016
                          • 22
                          I didnt understand half of what you wrote I'm afraid....!!!!
                            You wont he's a jok
                            • martin035
                              • Apr 2014
                              • 1308
                              Post#1 of the thread, copy and paste the dropbox web address into your browser.
