Sky ROI Sports channels
  • martin035
    • Apr 2014
    • 1308
    #16
    Originally posted by jon50
    mine is openvix
    i don't use openvix anymore, however, if I remember correctly its menu-setup-service searching then look for 'manual scan' then scroll your transponder channel to 12207 v 27500 then scan, this should give you another bouquet called 'last scanned' with both your ss5 ROI's in.
    • jon50
      • Mar 2014
      • 29
      #17
      ive done what you say martin and its only coming up with sky sports 1 to 5 uk not roi
      • joe516
        • 1000
        #18
        transponder channel to 12207 v 27500 is 100% sky sports 5 m8
        • martin035
          • Apr 2014
          • 1308
          #19
          It won't be added to your 'Sports' bouquet, you will have a new bouquet called 'Last Scanned' you'll find the channels in there.
          • jon50
            • Mar 2014
            • 29
            #20
            Looked in there Martin still no joy
            • martin035
              • Apr 2014
              • 1308
              #21
              You'll need a openvix user to tell you where the channels are located, sorry
                #22
                All of the popular 'Open' sourced images have ABM built in which will scan your channels correctly if setup correctly, follow Martin's very detailed and informative Guide and you wont go far wrong
                This Backup Image is for the Newer H series of Zgemma Satellite receivers, it will work on the H.S and H.2s and confirmed working on the H.2H by Hadron @post #116 (requires additional setup for cable see post #119) but hasn't been tested on the H5 Openatv5.3 Backup Image with New improved Sky Skin, OTA update safe ?
                • pupuqiop
                  • Sep 2015
                  • 41
                  #23
                  Originally posted by martin035
                  One of 2 ways either install Cwaites channel list, he has an Irish Fav which has SS5 ROI in it;
                  The latest CWAITE (previously sattv5) Sky Numbered Channel Lists can be found here. (http://cwaite.dyndns.tv) We now have an ALL Channels section in Favourites which contains all of the channels together (except the Non working HD channels and the test section)with no gaps, to get to this Press FAV on your Satellite Remote
                  Or do a TP_list search, follow the instructions in this thread;
                  http://www.digital-kaos.co.uk/forums...or-the-newbies
                  Thank a lot for this, found it at last!
