No signal from a motorized dish
  • den1
    • 63
    #16
    With you saying that you have a +3 degrees when you send the dish to a satellite, that could mean that you will have to move the motor on the pole by 3 degrees to get it right, this may solve it for you. (use 11747v 30000)
    DEN
    • Meyouall
      • Aug 2016
      • 10
      #17
      Does this Mean that I will always have to go to the motor and manually add 3 degrees after I change a channel or something?
      • den1
        • 63
        #18
        YES, When you are using USALS as your set-up, (if you set the motorised system up correctly you would not have to a change when you go to another satellite).
        There is a way around this if you do not want to get a ladder out and move the motor, use the DiSEqC 1.2 setup and to each satellite in turn and save.
        Hope this helps
        DEN
        • Meyouall
          • Aug 2016
          • 10
          #19
          managed to fix the problem. how i did it is written in my initial post in this thread.
