what is the connector called which comes from the sat dish and you have to connect to dreambox. i have just a plain black wire at moment. i have cut the end which shows the coaxial leads but need a connector ?
connector from sat dish
you mean f connecter.righhttp://www.google.co.uk/imgres?imgur...ed=0CA8Q9QEwAQ t?Last edited by mark36; 5 December, 2009, 15:02. -
i think thats the one do u just press it onto black lead ?Comment
How to fit F Connectors to coaxial cable
there you go mate .
bit easier than me explaining.
If you need these this afternoon
b&q,maplins etc will have them.
hope you get sorted
shouldn't worry about the grease thing though i've never used it(not for that anyway)
most F-plugs are screw on, strip about 20mm off the outer casing fold back the foil and copper mesh strip the inner insulation leaving about 3/4mm screw F-plug on trim copper wire to leave about 3mm showing past the end of the plug.
trial & error will get it just right.
you can get F-plugs in any hard ware/electrical store these days.Comment
