One dish, 3 satellites??
  • sachin_tendulkar
    • 13
    #16
    That is interesting. I didn't know that. Are you then configuring Port B just for your information (i.e you are selecting whether it is Astra 1 or Hotbird or does this config does actually matter)? When you do a scan on port B, I am assuming you will get all the Astra 1 channels as well as the Hotbird channels. Then depending on which channel you select, the monoblock switches to the relevant LNB. If that is the case, very smart.
    • .: JaCkPoT :.
      Retired Sat TV Addict
      • 5607
      #17
      om my understanding thats true so now hopefully you have made your decison in what to do from this thread and fronm the support of the forum
      ___________________
      In the good old days, I had
      DM800s HD
      Openbox S10
      TM500
      DM500s
      90cm FortecStar dish
      Maxx 110cm Dish
      Technomate 2300 Motors
      • sachin_tendulkar
        • 13
        #18
        Thank you all for your responses. It makes hell of a lot of sense now on how the monoblock LNB works. I will look at this setup in a more detail later as I understand the basics now.
        • djpopeye1971
          • Apr 2010
          • 165
          #19
          3 sats on one dish zone 2 got 28.2 19.2 and 13.0 east can get nove but not jsc sports anyone got any ideas why could do with the help
          • rigsby71
            • Mar 2009
            • 676
            #20
            A bigger dish
            • djpopeye1971
              • Apr 2010
              • 165
              #21
              i been told its ok the one i have i live in the north west
              • ramjet
                • 2995
                #22
                if nova is good signal and quality then there should be no problems getting jsc, just ensure you have some skew on the lnb
                jsc ok on transponder 11296 H s/r 27500
                • djpopeye1971
                  • Apr 2010
                  • 165
                  #23
                  s is 83% q 47%
                  • ramjet
                    • 2995
                    #24
                    s is 83% q 47%
                    there is your problem then, its half what it should be
                    • djpopeye1971
                      • Apr 2010
                      • 165
                      #25
                      any ideas how to get it up 28 and 19 are fine am a bit new to this mate
                      • ramjet
                        • 2995
                        #26
                        needs adjusting up-down-left-right until you get about 80% to 90% quality, not 45%
                        also depends if you used it as prime focus or not ?
                        • djpopeye1971
                          • Apr 2010
                          • 165
                          #27
                          i used 19.2 as the main
                          • ramjet
                            • 2995
                            #28
                            thats probably why then, as 13e may have been a better focus
                            so you have to move the hotbird lnb until you get over 65% quality and aim for about 80% or more, and that may mean it needs to go higher or lower, never mind left or right, and skewed partly clockwise too
                            the lnb rack will be angled to take account of this but may need a greater or lesser angle
                            • djpopeye1971
                              • Apr 2010
                              • 165
                              #29
                              i try moving it up and down see what i get cheers mat
                              • djpopeye1971
                                • Apr 2010
                                • 165
                                #30
                                which is the weakest nova channel
