One dish, 3 satellites??
there hoorayComment
done it mate 80 cm dish long arm inverto dish still no joy but i cant understand why 28.2 e looking from the back is on the rightComment
because the satellite is on the left when looking from the rear of the dish , the signal hits the back of your dish and is reflected off to the right, so the lnb collector has to be on the right to receive it (looking from the rear of the dish)
its like kicking a ball at an angle against a wall, it bounces off the wall away from the kicker at an angle so would need a receiver (goalie) placed at an angle too
its a bit like those early consoles where you play tennis with bats and a ballComment
ramjet very well explained imao here i just have to keep trying to get it right would it be easier to try set the dish to 13.0 eastComment
Just be warned if you do align the main focal point to 13? east the you will start struggling with 28.2? east as the span increases from a mere 9? to 15? if you where using a 1m dish this would accept the larger span due to the dishes larger surface area.
At present with 19.2? east being the focal point you have roughly the same span between 13? and 28.2? of around 6.5?
Regards
digicon really cant understand why i cant get jsc i was wondering weather it was due to me setting it up on ground level about 7 feet in the airComment
Why don't you try a single LNB set up on same dish on hotbird,
Then you will know if it is your set up or not,
If you still have the same problem with jsc then you can focus on rectifying that problem, if you are picking up jsc on a single LNB set up then you will know where your problem lies.
If you have a good satellite meter you should have no problem picking up these 3 sats,
But if you are using one of the cheap meters you may never get this set up bang on.Comment
