hello to all
just install an 80cm motorised system with diseqc, the installation bit is easy but now having problem aligning the dish. i have manage to aling 1 degree west ( thor and the signal is very good. now setted up the diseqc by entering the lat and long. but when i go to astra 28.2 they receiver does not lock on the sta and therefore there is no signal. if i try hotbird 13degree east and astra 19.2degree east i get the same problem. can anyone please advise me where i am going wrong.
thanking you
icaicm
thanking you
icaicm
I've a similar hiccup with my new 1mtr motorised set-up , i'm new to sats so please bear with me . It's a DM500s with an Alsat darkmotor mounted on a perfectly level 1.5mt heavy steel scaffold pole , held by 2 beefy "K" brackets.
Thanks again for your help , but i'm afraid it's been another fruitless afternoon in my little sat world!
Thanks for that again Mate , i've just been on dishpointer.com and the direction line at 1w looks identical to the direction i have it pointing now ? . Two other bits of info on this site in the dish set-up data show , elevation 29 degrees and LNB skew -1.3 degree , but i don't know what this means in relation to my present 53.4 degree latitude setting on my dish , as per Krazylegs tutorial ? , maybe i'm just running before i can walk !
