Required Dish Size Guide
  • Nutsandbolts
    • Oct 2011
    • 1168
    #46
    Originally posted by roystheboy
    hi what size dish do I need for the sat Sirius I am down in South Wales thanks take care
    Hi. For the Welsh valleys i would have thought a 80cm dish should be ok . If you have a motor then its probably best to have a 1m - 1.2m to guard against those Welsh winds and storms etc.....
    Take care.
    • roystheboy
      • Feb 2010
      • 41
      #47
      Hi thanks so you recon a 1.2mtre dish would be fine for me in South Wales for the Sat Sirius and Viasat channels ,I got to make my mind up quick because a engineer wants to order one for me in the morning ,at a cost of ?250 fitted I dont mind that as long as will work ,hope you can confirm for me cheers take care
      • roystheboy
        • Feb 2010
        • 41
        #48
        Hi I already got a 1.0 mtre dish it works fine at 11.30 in the day but about 5.oclock in the evening it breaks up and I lose the picture ,thats my problem cheers take care
        • Nutsandbolts
          • Oct 2011
          • 1168
          #49
          Hi. To be honest i dont think its going to make much difference if you have a 1.2m dish. Reason for you losing the channel(s) is that the satellite may be reducing the output power at certain times and you lose coverage in Wales. On that basis i personally would not spend 250 pounds just on a dish with no guarantees. Why dont you wait a few days and see if you get any feedback from members who receive VIASAT channels. You certainly dont want to spend 250 pounds for nothing.
          Regards
          • nimbers
            • Mar 2010
            • 82
            #50
            Is this definately a signal issue??? mine was doing a similar thing on 28.2east i later found out threw various forums that it was a peak time for server and that my supplier at time had over subscribed to customers on his server
            Just a theory there
            • roystheboy
              • Feb 2010
              • 41
              #51
              Thanks guys thats a great help ,still not sure what to do though dont think its the server as I get all channel on other Sats ,I would really get this dish if it worked around the clock thanks again take care
              • mdt
                • 3034
                #52
                whats the big need for the viasat channels anyway? since they stopped the 3pm,s theres only 1 game on sat anyway. you must also realise that a 1.2m dish is very heavy and will probably require a 36v motor/polar mount aswell as a heavy duty wall mount as i know from experience that a usals motor struggles with such a big dish. what type of dish has your installer suggested as if its anything other than a gibertini or andrew then its probably not going to be worth it as when recieving out of footprint birds then they usually suffer from really bad rain fade. try a inverto black ultra lnb first as they are only a tenner and they should give you a extra 1db of signal on weak txp,s on the nordic beams of sirius although the nordic beams also vary in signal strength ive found,regards mdt
                • Nutsandbolts
                  • Oct 2011
                  • 1168
                  #53
                  Which is why i said dont waste 250 pounds on something that may not resolve the problem anyway.
                  Regards
                  • roystheboy
                    • Feb 2010
                    • 41
                    #54
                    Hello thanks again I got a 1.0 channel master dish and the installer said he would replace it with a 1.2 channel master ,and he hasnt come yet LOL
                    • roystheboy
                      • Feb 2010
                      • 41
                      #55
                      Hi and where would I get a LNB like you said thanks again
                      • Manic01
                        • 5117
                        #56
                        ebay...............
                        • roystheboy
                          • Feb 2010
                          • 41
                          #57
                          Hi and how is it fitted does it go as close as it can to the dish or is it set right back to the clamp thanks take care
                          • Manic01
                            • 5117
                            #58
                            Mines in middle.
                            • roystheboy
                              • Feb 2010
                              • 41
                              #59
                              hi and is there an increase of signal
                                #60
                                If you have a Channel master 1m then i would assume you also have the matched feedhorn to go with it as this is the best solution rather than going with a Black ultra LNBF, if you do have the matched feedhorn then you could try a Black Pro C120 which is slightly better specced than the Black Ultra but which is made for CM's and Gibertini 1.2's.
                                f you are using a standard LNBF then go with the Black Ultra which has a very long neck and is ideal for adjusting the focal lengh to match your dish.
