Required Dish Size Guide
    #76
    Originally posted by lee11168
    hi everyone im near bolton can i get 28.2/13e/19.2. if i change my dish from s** minidish 45cm to a 60cm dish but has to be fixed with multi lnbs {got boring neighbours and dont want to upset them}
    Yes you certainly can but an 80cm would be a lot better for 13? east
    • lee11168
      • Feb 2011
      • 217
      #77
      wife wont let me put 80cm up. im going to have to try and do it myself i have had 2 installers up that said it cant be done.have you any ideas what i need to buy
      • mdt
        • 3034
        #78
        you will lose some transponders in the rain using a zone2 sly dish for 28.2e/19.2e/13e, can you not mount the dish at the back on a T+K,pole arrangment so you could use a 80cm.it requires more work and is a bit more expensive but if it cant be seen unless looked for you will keep the boss happy.regards mdt
        • sootylfc
          • Nov 2011
          • 10
          #79
          looking for a motorized dish to be install in the Merseyside area - It will be used for the 3pm football once the season starts again
          So i am guessing i need to pick up
          13E
          19.2E
          26E
          Any others ?
          • leez
            • Mar 2009
            • 321
            #80
            whats the crack with 3 east ... lads.. north east England here ... haven't even got it pre installed into me meter ...have to put some new software in ..
            dreambox 800 tech 500 ( ubuntu 10 .04)... 1 m dish v box 2 acuator ..
              #81
              What meter do you use
              • leez
                • Mar 2009
                • 321
                #82
                horizon m8 .got 2 old hdsm and the newer usb type one
                  #83
                  Well its definitely there for the USB one as i just checked the Settings download and they have the V TP for Eutelsat 3D listed, You also have 10 pre-definable ones that you can add custom TP's yourself
                  • leez
                    • Mar 2009
                    • 321
                    #84
                    aye m8 ..just need to load in off horizon site..just ondering if I could pick up and if anything footie wise was on it m8 ..cheers
                    • shankill2012
                      • Feb 2010
                      • 285
                      #85
                      Updated dish size list from "William-1" April 2017. This Dish size guide is for Ku Band Satellites received in the UK Revised & updated April 2nd 2017
                      Intelsat-20-----------------------68.5?east-----100cm
                      Intelsat 17-----------------------66?east-------80cm (European beam - mainly data services)
                      Intelsat-902 ---------------------62?east-------100cm
                      NSS-12----------------------------57?east-------80cm
                      Yamal-----------------------------54.9?east-----80-90cm (European beam)
                      Yamal-----------------------------54.9?east-----1.2m (Northern beam in central UK)
                      Express AM-22 --------------------53?east-------80cm to 120cm
                      Yahsat----------------------------52.5?east-----80cm European beam.
                      Lybid-----------------------------48?east-------80cm (Due to launch 4th Qtr 2017)
                      Intelsat 10 (incl. 1.3?)----------47.5?east-----100 to 120cm
                      AzerSat-1 ------------------------46?east-------80cm (West beam)
                      AzerSat-1 ------------------------46?east ( No reception on East beam with 100cm)
                      Intelsat-12 ----------------------45?east-------70 cm
                      Intelsat-904----------------------45?east-------60cm
                      Turksat 2A/3A/4A east ------------42?east ------80cm for West Beam reception
                      Turksat 2A/3A/4A east ------------42?east ------180 to 300cm East Beam
                      Hellas-Sat-2 ---------------------39?east--------60cm to 80cm,
                      Eutelsat-36B----------------------36?east--------100cm reception only for European beam---
                      Eutelsat 31A----------------------30.9?east ----100cm
                      Eutelsat 33A ---------------------33.2?east ----100cm
                      Astra-5B--------------------------31.5?east ----120cm to 240cm
                      Arabsat 5A -----------------------30.5?east ----reception possible with 150 to 240cm in the UK
                      Astra 2E -------------------------28.5?east-----45cm to 60cm.
                      Astra 2F/2G-----------------------28.2?east-----45cm to 60cm.
                      Badr- 4 --------------------------26?east-------100cm to 120cm = South UK ----- 120 to 180cm = North UK
                      Badr-5 & 6------------------------26?east ------No reception with 100cm dish in the UK
                      Eutelsat 25B / Es'hail-1 ---------25.5?east---- No reception with 100cm dish in the UK
                      Astra--3B-------------------------23.5?east ----80 to 90cm
                      Eutelsat-21B----------------------21.5?east ----90 to 120 cm
                      Astra-1-KR/1L/1M/1N---------------19.2?east-----45cm South UK----60cm North UK.
                      Eutelsat 16A----------------------16?east ------80cm
                      Eutelsat Hotbird13B/13C/13D-------13?east-------60cm
                      Eutelsat-10A ---------------------10?east-------90 to 120cm
                      Eutelsat -9A ----------------------9?east-------70cm
                      Eutelsat-7A/7B --------------------7?east-------80cm
                      SES-5 -----------------------------5?east-------120 to 240cm for this Nordic beam
                      Astra 4A---------------------------4.8?east-----100 to 120cm Nordic beam
                      Astra 4A --------------------------4.8?east-----80cm European beam,
                      Eutelsat 3B -----------------------3.1?east-----100cm
                      BulgariaSat 1----------------------1.9?east-----80cm (launches in May 2017)
                      Thor-5/6/7--------------------------0.8?west----80 cm European beam
                      Thor-5/6/7--------------------------0.8?west----100 cm for Nordic beam in South East England
                      Intelsat-10-02 ---------------------1?west------90cm
                      Amos-3 & 7--------------------------4?west------100cm to 180cm no reliable service in UK
                      Eutelsat 5 West A ------------------5?west -----80cm.
                      Nilesat 201 ------------------------7?west ----------------(No reception in UK with 100cm dish)
                      Eutelsat 7 West A-------------------7.3?west-----------100cm South East England
                      Eutelsat 8 West C ------------------7.8?west------------ (No reception in UK with 100cm dish)
                      Eutelsat 8 West A-------------------8? west------------100cm.
                      Express AM44------------------------11?west------------90cm
                      Eutelsat 12 West A -----------------12.5?west ---------90cm
                      Express-AM8-------------------------14.0?--------------80cm
                      Telstar-12 -------------------------15?west -----------90cm
                      Intelsat-901 -----------------------18?west -----------90cm
                      NSS-7 ------------------------------20?west -----------90cm
                      SES-4 ------------------------------22?west -----------90cm
                      Intelsat-905 -----------------------24.5?west----------90cm
                      Intelsat-907 -----------------------27.5?west ---------90cm
                      Hispasat 30W-4/30W-5---------30?west------------80cm
                      Intelsat 25-------------------------31.5?west----------100cm
                      Hylas 1-----------------------------33.5?west----------100cm
                      Intelsat-903 -----------------------34.5?west ---------90cm -----(Occasional feeds)
                      Intelsat 35e------------------------34.5?west ---------90cm--(Launch 30 April 2017)
                      Telstar 11N ------------------------37.5?west ---------90cm -----(Occasional feeds)
                      SES-6 ------------------------------40.5?west----------90cm mainly data
                      Intelsat-14-------------------------45.1?west----------90cm
                      Intelsat 34-------------------------55.5?west----------90cm mainly data
                      A few extra details added - A/S
                      Updated by William-1 (thanks to all members who have contributed to this list)
                      All credit to. - "william-1"
                        Try looking at a wave frontier toroidal dish. I've had both the T90 and T50. Both worked well.
                        • .: JaCkPoT :.
                          Retired Sat TV Addict
                          • 5607
                          #87
                          I have updated the first post in this thread to the latest information - thanks for the update.
                          ___________________
                          In the good old days, I had
                          DM800s HD
                          Openbox S10
                          TM500
                          DM500s
                          90cm FortecStar dish
                          Maxx 110cm Dish
                          Technomate 2300 Motors
