What guys think about this?
change polarisation on LNB(modification)
Takes me back, I haven't seen anything on circular polarisation since he 1990's and the old Marcopolo -> Thor 1/Sirius days. Using a normal veritcal/horizontal LNB didn't stop you getting L/R polarised signals, it just meant that the signals were weaker and more prone to breakup. I don't know anything that I can receive that uses L/R nowadays.My master plan is to live forever..... going to plan so far
what about Intelsat45' E and Amor 4'W? plenty channel with L/R poralisation?Takes me back, I haven't seen anything on circular polarisation since he 1990's and the old Marcopolo -> Thor 1/Sirius days. Using a normal veritcal/horizontal LNB didn't stop you getting L/R polarised signals, it just meant that the signals were weaker and more prone to breakup. I don't know anything that I can receive that uses L/R nowadays.Comment
Aye but if you get them you tend to be on a motorised setup, which means if you modify your only LNB on a motorised system that the H/V signals will not be as good surely.
Not a problem if you're static and have multiple LNB's though.My master plan is to live forever..... going to plan so far
Some very good channels are there.
I want to try with one sky lnb which I disconnect from one mini sky dish,but no have enought time to do it.
Maybe this weekend I will do that? I will post the results.Comment
