What do i use to open the file people? Word/notepad etc dont seem to accept it?
sky box engineer tricks
Hi numptyno1
I don't think it is your fault, there are a few dammaged file lying around, but if you go back to post no:2 of this thread, you will see some step by step instructions.
Hope this helps m8
IanComment
Hi barneybetty,Originally posted by barneybettyHey there this is my first post so need to get it done to get access to sat and cable info would like to update my home entertainment in general sorry if readin this is a pain thanks.
If you would have read your welcome email, or looked @ the top of the forums list,
you would have seen that you should have made your first post here:
Introduce Yourself
So why don't you go there now & introduce yourself...
All the best
IanComment
New Sky card
Has anyone else had the same problem? Since changing the to the Sky card on my Sky HD box I have had nothing but problems.
Freezing, no sat signal etc. It will not accept my previous card and Sky do not seem to want to know!
Anyone had a similiar problem?Comment
try turning the system off, unplug from the mains (leave off for 1 minute) , give your card (chip side) a wipe with a damp cloth, put card back in and switch system back on.Sky+ HD Spiderbox 9000hd TM 5400 ci+ 90cm dish motorisedComment
Sky HD Setup Menu
Press Services followed by 0, 0, 1 and Select
This will then display the Setup Menu
Use Sky+ Rebuild first as this will retain and recordings.
If no use Sys Reset will erase all recordings and planner info.Last edited by TrevorW; 28 January, 2010, 21:24.Comment
I phoned sky who did stage 1 with me, this did not work and they said i would need an engineer at ?65. I said i would think about it not having any spare cash for this luxury. I tried your stage 2 as illustrated on here and it worked. You saved me some stress and money. Thank you! PS, if I was elderly I would have paid the money thinking that sky know best.... they could have done stage 2 with me over the phone. Disgusted with sky.Comment
