sky box engineer tricks
  • numptyno1
    #16
    What do i use to open the file people? Word/notepad etc dont seem to accept it?
    • ianmac
      • Oct 2008
      • 922
      #17
      Hi numptyno1
      I don't think it is your fault, there are a few dammaged file lying around, but if you go back to post no:2 of this thread, you will see some step by step instructions.
      Hope this helps m8
      Ian
      • ianmac
        • Oct 2008
        • 922
        #18
        Originally posted by barneybetty
        Hey there this is my first post so need to get it done to get access to sat and cable info would like to update my home entertainment in general sorry if readin this is a pain thanks.
        Hi barneybetty,
        If you would have read your welcome email, or looked @ the top of the forums list,
        you would have seen that you should have made your first post here:
        Introduce Yourself
        So why don't you go there now & introduce yourself...
        All the best
        Ian
        • darkhelmet
          Is there any info on pairing boxes ?
          • tantricman
            New Sky card
            Has anyone else had the same problem? Since changing the to the Sky card on my Sky HD box I have had nothing but problems.
            Freezing, no sat signal etc. It will not accept my previous card and Sky do not seem to want to know!
            Anyone had a similiar problem?
            • bosvelt
              • 262
              #21
              try turning the system off, unplug from the mains (leave off for 1 minute) , give your card (chip side) a wipe with a damp cloth, put card back in and switch system back on.
              Sky+ HD Spiderbox 9000hd TM 5400 ci+ 90cm dish motorised
              • Gshrubby
                What's the secret menu?
                • csafc
                  #23
                  has anyone ever actually got free foreign channels????
                  • game111
                    No signal
                    Channels 101 - 105 are showing ok, but rest of sky channels there is no signal. Any ideas ? Many Thanks
                    • bcoole
                      Reset with Neew Sky Guide
                      How can you reset on a sky hd box with the new sky guide - there is no System Setup menu option. I am getting No Satellite Signal message but signal is fine on neighbors box who is using same dish.
                      • oknar71
                        has anyone have solution for sky digital smart card -clone or somethingelse thnks
                        • TrevorW
                          Sky HD Setup Menu
                          Press Services followed by 0, 0, 1 and Select
                          This will then display the Setup Menu
                          Use Sky+ Rebuild first as this will retain and recordings.
                          If no use Sys Reset will erase all recordings and planner info.
                          • PAUL7331
                            • 163
                            #28
                            Guys, does the viewing card need to be inserted to view ITV HD? Ive added channel manually, but it doesnt show up in the other channel menu where it should! Does viewing card need to be inserted for it to work?
                            • red7
                              • Feb 2010
                              • 5
                              #29
                              has anyone got free foreign channels?
                              • charles4
                                • Feb 2010
                                I phoned sky who did stage 1 with me, this did not work and they said i would need an engineer at ?65. I said i would think about it not having any spare cash for this luxury. I tried your stage 2 as illustrated on here and it worked. You saved me some stress and money. Thank you! PS, if I was elderly I would have paid the money thinking that sky know best.... they could have done stage 2 with me over the phone. Disgusted with sky.
