sky box engineer tricks
Sky Sports 403
I live in Bulgaria and use to get all the sports channels, now for some inexplicable reason I can't get 403 or 409 non HD on my Sky Plus HD box.
Should I perform a reset or can you suggest something else?
Tnx
ArdleystarComment
information given is to be used for educational purposes only
Don't Forget To Say Thanks If You Like My Post
IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
If It Ain't Broke Don't Fix ItComment
If you reload the firmware following the instructions above " STAGE 3 "your recordings are still there, as soon as your into the box goto the planner and then the trash can and delete everything in there it could take a while but fixes the crashing problems. When they added the undelete function it created a problem where items in the trash can build up and the hdd becomes full, then when either you try and record or more often they add programmes for the on demand straight to your box it crashes the hard drive. going to catch up was nice especially when it said available now without down loading but its not so great when the hdd is full and you've forgot to delete the deleted programmes again.Comment
