Coming Soon QBOX HD-Mini for only 199 Euro
[ame=http://www.youtube.com/watch?v=pXZrswxySt4&feature=player_embedded]YouTube - QboX HD Mini.m2ts[/ame]
30. June 2010
QBOX HD mini
Main CPU STi 7101
Twin Tuner (DVB-C / DVB-S2 / DVB-C)
Tuner Plug N Play
Enigma 2
3 USB Ports
HDMI
LAN
WiFi Connection (optional)
2 Cardreader
2" TFT Display
Diablo Inside
Channel cahnge under 2 sec.
Easy and fast GUI navigation
compact size same performance
SOON ON MARKET FOR 199 EUR
I think many of you Guys will ditch the idea of a Clone Dreambox, Technomate 800 HD and other receivers after seeing this.... Hopefully the price will be what is been advertised, but with only client Cccam support it will not suit most of us...
- 266 MHz ST40 CPU SH4 Core. STi 7101 based.
- Linux Operating System (ENIGMA 2)
- Linux DVB-API compatible.
- 2,2” TFT high definition Display
- WiFi - 802.11n. Stand-Alone internal Module (opzional)
- Ethernet 10/100 MBit compatible interface
- MPEG-2 / H.264 Hardware decoding
- Tuner: DVB-S2, DVB-C, DVB-T
- 2 x Tuner Module Input - Plug&Play 1 SAT + 1 DVB-T (DVB-T optional)
- 2 x Smartcard-Reader ISO 7816-3 with programmable clock speed
- V.24/RS232 Interface
- 10/100Mbit Ethernet Interface
- 1 x Scart (RGB, FBAS or S-Video)
- HDMI Output
- 2 x USB 2.0 external USB
- 1 x USB 2.0 internal for FileSystem
- S/PDIF Interface for digital bit stream out (AC-3)
- 8 MByte NOR for Secure Bootloader, 128 MByte RAM
- unlimited channel lists for TV/Radio
- EPG (electronic program guide)
- multiple LNB-Switching control (supports DiSEqC)
- OSD in many languages and skin-support
- Videotext Decoder
DVB-S2 Tuner:
- Frequency Range 950 .... 2150 MHz
- Demodulation DVB-S (QPSK); DVB-S2 (8PSK,QPSK)
- Symbol rate DVB-S: 2 ... 45 Mbaud/s, SCPC/ MCPC
- DVB-S2: 10 – 31 Mbaud/s (8PSK) , 10 –30 Mbaud/s (QPSK)
- Video decoder:
- Video Compression MPEG-2 and MPEG-1 compatible, H.246
- Video Formats 4:3 / 16:9
- Letterbox for 4:3 TV-Device
- Capable Resolution: (1080I, 720P, 480P/576P, 480I/576I)
- Audio decoder:
- Audio Compression MPEG-1 & MPEG-2 Layer I and II, MP3
- Audio Mode Dual (main/sub), Stereo
- Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
Video parameter:
- Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
- Teletext filter in conformity with ETS 300 472 Standard
- Output: FBAS, RGB, S-Video, HDMI
Serial Interface RS 232:
- RS232 bidirectional
- BitRate 115,2 kBit/s max.
- Plug Connector SUB-D-9
- USB
- 2 x USB 2.0 Host
- 1 x USB 2.0 Host Internal Slot for USB stick to hold the Firmware.
Count of active satellite positioniSEqC 1.0/1.2 SAT POSITION / SAT OPTION
- DiSEqC - Rotor Control
