goto 13.0 east hit a pron chann it should unclear in few secs,,have you updated all the firmware via usb..only takes 5mins to setup a spider-box...
spider box with gift
you could try rebooting your modem and router then give it a couple of minutes and then try again. if it still wont clear do a stb reboot via the remote control. regards mdtYES, when I go to menu/options/network//net application/authorization/nuevoXstream Authorization/Register. It tells me the key is already registered. So I guess I am registered but all the channels are still scrambled. Not even one is unscrambled. I have been on this for weeks. When I connect to the internet it tells me when my gift package will expire.
Is there anything else I can do.DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
Internet service providor!!!!!!!!!!!!!!!!!!!!!!!!
********************************************Its got nothing to do with internet speed ! its got to do with the speed of the encryption refreshing, NDS been the fastest requires a quick connection and requires your Peer to either have a fast broadband connection, or live cose to you geographically with around a 2-3 second card refresh rate
Other Encryptions like N3 refresh at between 4-6 seconds depending on which rom the provider is using giving plenty of time to clear the channel before the next key pops up, thus sharing with much of Europe with ease.
Other encryptions such as Seca, Viaccess, Irdeto, Cryptoworks can be as much as 9-12 even 15 seconds refreshing while Biss & ConstantCw can last days before a new Key much like the old N2.
To get a good service look for a provider that uses a Slow refresh rate Encryption & the country with a reasonable population where there will be a higher share / reshare rate.
You should be able to get most providers with a min ISP service even as low as 2 Meg Broadband with ease, including Downloading, game console & browsing at the same time on other devices.
At last someone with some sence, This IS HOW IT WORKS!
Thank you for saving me the time to explain again and again. Well done.
get on your or off your box, with a bong!
At least once a month,
You only live once!Comment
Spiderbox and Vissat Denmark
Hi,
I dont want to hijack this thread but I 'm looking for an answer to 2 questions:
1- Does the box clear Viasat Denmark on Siruis and canal Digital on Thor.
2-What happened after the gift expire -after 1 year I guess-
Regards.TM 3300 / DB 500S / Triax 110 / Sat 0.8W-42E
hi,
yes to Thor no to Siruis, if you go on A*sat forum they reckon it is being extended, possibly and hopefully like the ProtekComment
My god what have i been missing, i have a technomate 1500ci 1m motorised dish, it is just a plain just plug in and go with the spider box 9000 , will i have to change my lnb , thanks for advise in advance, thank youComment
no you will not have to change your lnb.
its nearly plug and play but not quite consult the dealer you bought the box from as you will need to install a patch.Comment
Spiderbox Motorised
I am tempted to buy the spiderbox 9000 hd with a 1m motorised system off fleabay, can anyone tell me what exactly i will receive via this as i dont wana be forking out nearly 400 squid for nothing! i am really after prem footy 3pms etc and also something for the mrs like HBO to watch desperate housewives. Is there anyway of finding what will be open and what wont.
Hope somebody can helpComment
