Well, card has NOT been updated in the original digibox..I have done a forced update and then left card in original digibox for many hours...Has anyone got any other ideas ?? Is it safe for me to turn on Automatic updates within Newcs ? And will this update the card even though i only have 2 connections in the Newcs panel
sky 1 updating card
Thanks for the help......I decided this morning to wait until 1 week before its due to expire, then it will go back into the original STB.....I cannot do with all this messing about.....I was really happy with CCcam updating my card, but when loads of cards got dmamged by a bad update, i am reluctant to use CCCam at the moment..Kindest regardsComment
good idea matey, play safeWavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
previous life dm800hd and 500c on cable
screw you nag3
sky 1 updating card
Wots emm mean m8 lm learning
any information provided is for educational/experimental purposes only.Comment
sorry...my mistake.....
I shall get my coat.......Last edited by ITS A SCAM !; 3 July, 2010, 15:26.Comment
Ansem
different kind of update glic
these are entitlements updates for the card, these updates are got in stream via either the original stb or or your dreambox using cccam or via your peers etc, the other update is a firmware update for the original stb that WILL wipe your recordings, its basically a factory reset for sky boxes that wipes everything and updates the firmwareComment
this is what i was refering to m8 if it is forcing an update of the card and an update of the firmware will it wipe whats recorded on the boxYou don't have to wait for an Update you can force an Update, Place the card into the Sky Receiver and follow.
1) Locate the button on the front of the Receiver, named "Back Up".
2) Press and hold down the "Back Up" button...
3) WHILE HOLDING IT DOWN, disconnect then reconnect the power to the receiver (do not release the back-up button yet).
4) About 20 seconds after reconnecting power, all four coloured lights will illuminate on the front of the receiver.
If the TV is switched to Sky a message will also appear on screen.. "Updating System Software".
5) Only after the four lights illuminate and the message appears should you release the back-up button.
6) After about 10 minutes the reciever will return to "standby" (ie. red LED only).
7. Leave the receiver in standby for 1 minute as it carries out a self check.
8). Switch receiver out of standby (green LED illuminates).
9) The receiver will take a few minutes "Searching For Listings".
This will update the firmware of the receiver and any card updates you have missed.Comment
If you the owner of that card, just got to Activate my channels, if you not registered do so, and activate your card. Make sure card is on his receiver
It comes back on nearly instantlyComment
