Astra 28 and 19 plus Hotbird 13 on one dish?
  • rooni
    • 5
    Hi Is it possible to have astra 19 and 28 deg plus hotbird 13 on one dish i live in north manchester.
  • mdt
    • 3034
    yes m8, ive seen it done using a zone 2 65cm eliptical dish here in bolton using 3x 0.1db smart lnb,s hooked up to a maxx1000 and it works great although if i were installing one id choose a 80cm dish for extra heavy weather protection. regards mdt
    • alunfennell
      • Oct 2008
      • 1525
      I have it working on a 80cm dish with 28e been the prime satellite, with a Mono-block next to it receiving 19e & 13e, I had to make a extra Bracket due to the weight of the Mono-Block especially in bad weather.
      But Yes it does Work.
      **The Worlds Best Interactive F1 Strategy Game**
      • thijs
        • Apr 2010
        • 1096
        have it working with a triax 90cm dish and triax bracket with four quad lnb'S one extra for astra 23.5 never any problems in ireland anyway
        Everything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.
        • davvo
          • Apr 2009
          • 666
          i have 28.2 23.5 19 16 13 5 east
          homemade bracket
          1m lenson heath dish
          will add 10 and 42 east
          i made the bracket like this
          50cm length of ali tube
          bolt that to dish arm with a small plate i made
          then made the lnb holders like in pic
          slide lnb holders on ali tube
          screw the hanger on the bolt up and down for elevation
          to make lnb holder
          get a jubilee clip that fits around lnb
          drill a hole at bottom of clip
          put a 2 or 3 inch length bolt through the hole
          put a nut and washer on it
          get a small jubilee clip wrap around tube so it looks like a p clip (see pic2)
          drill 2 holes
          slide that on bolt put a nut and washer on each side
          to make the plate that fits to lnb arm and holds the tube
          i got a flat peice of metal drilled 2 holes and fixed to dish arm
          at tube end of plate i bent plate down a little drilled 2 holes
          in plate and tube (see pic 3) and fixed with small nuts and bolts
          cost ?2 to make 6 lnb holders
          ali tube cost me nothing
          • ash08
            • 20
            davvo that is some epic blue peter shit ya got goin on there ha quality
            • davvo
              • Apr 2009
              • 666
              yeah not bad for a 20 year old 1m lenson heath Ali dish
              and the 18 lnbs i got for nothing
              and the free DM800
              all i bought was the diseqc switch and and inline amp
              • fattahalizadeh
                • May 2012
                astra 28 and hotbird
                Hi everyone
                I'm completely new in this forum.
                Is it possible for me to have Astra 28 and hotbird satellite in one dish while I'm living in Dublin. Ireland?
                Tanx
                • Nutsandbolts
                  • Oct 2011
                  • 1168
                  Hi. Guys why not invest in a motor?? I think its a lot cheaper and maybe less hassle...Take care.
                  • davvo
                    • Apr 2009
                    • 666
                    i have a motorized as well as a multi lnb set up all working from one box
                    i get instant zap on 6 sats 5 from the multi lnb and 1 from where i park the motor
                    • Nutsandbolts
                      • Oct 2011
                      • 1168
                      Hi davvo. Very impressed. Do you have 2 dishes and a disecq switch for the LNB's?? Regards
                      • ramjet
                        • 2995
                        mine is connected as instant zap on 28e on 3 and 30w on 4and the first position (one) is my darkmotor for the rest, using a 4 way diseqc switch
                        and as I use a twin output inverto ultrablack lnb, the second output feeds an 8 way switch with 5 fixed lnb,s and one being the second feed from the motorised triax td110 dish
                        and to answer the dublin question, providing the dish is big enough to cope , say 80cm to 110cm then yes you should get 13e and 28e on the one dish, and 19e as well
                        • davvo
                          • Apr 2009
                          • 666
                          yeah 2 dishes 1 motorized and 1 multi lnb
                          going to a 8 way disecq switch then to a dm800
                          • davvo
                            • Apr 2009
                            • 666
                            just one problem tho
                            i hardley watch the bloody thing
                            spend more time tinkering with it
                            • Nutsandbolts
                              • Oct 2011
                              • 1168
                              Hi davvo. Cant believe you hardly watch the bloody thing. You must have better things to do then. If you like tinkering so much see if you can conjure up a magic patch that will open everything for us. Take care.
