I have 6 lnbs on a TD88 and an 8 way diseqc, but like davvo, I tinker far more than I watch
Astra 28 and 19 plus Hotbird 13 on one dish?
I think you got your answer from another forum LOL and they basically said the same as me you would struggle with the Bar angle set as it is now and then the skew of the LNB's.
If you are going to motorise your dish then your prime focus now will have to change from 4.8? east back to 0.8? west, and as you where informed only your prime focus LNB would work on the dish and not the others. Until you returned the dish to its original position set for Multi LNB setup
Hi. Why not have one fixed and one motorized?? Problem with having multi lnb's on a motor is you have no control over them. Everytime you move the dish all the lnb;s will move as well so how you going to set them up. Problem also in setting up the lnb's using diseqc switch , if you keep changing satellites your switch wont pick up anything.
Good luckComment
