Blade Media BM7000HD
  • ub26
    • Feb 2011
    • 9
    #151
    Just installed firmware 122p works a treat with the 7-day EPG.
    got the full 9991 menu aswell
    • redondo5
      • 277
      #152
      Latest firmware is great
      Just need slightly better interface to display epg and maybe ability to save epg descriptions on to USB if the on board memory is too small... The peg shows programme titles but not descriptions. Still great option and with 1080p media streaming possibilities this box is right up there for it's price range
      • ub26
        • Feb 2011
        • 9
        #153
        Im in UK using sky UK, on firmware 122p with the 7day EPG
        Has anyone sorted the problem because I don't seem to get 7 days EPG.
        • ub26
          • Feb 2011
          • 9
          #154
          Hello
          After doing some research, I realised that Sky UK on 28.2e stream the EPG through a separate channel rather than the same channel which other satellite providers do.
          What you need to do is find Sky UK EPG channel on your box
          It can be found on this satellite stream
          Astra 2A (28.2E) - IEPG data 1 - 11778.00 V - 27500 2/3 - SID 4189
          You need to manually tune it if you don't have the channel. The channel itself is found under radio rather than TV
          If you have the CNDF file from blade, dont worry about manually adding the channel or if you havent deleated it.
          Find 'IEPG Data 1' Under radio section on your box and stay on that channel for about 5 Minutes
          You should then have a full EPG, The longer you stay on it the more EPG data the Box Downloads.
          I estimated about 10mins for a 7 day listing.
          • francij
            • Apr 2011
            Hi,
            I am new to all this and thinking of buying one of these boxes, i am a complete novice!
            If i buy the box is it possible to connect to a sky dish, connect Ethernet connect to servers then i am all set up?
            Regards
            • lincsat
              • 1228
              #156
              You can load the patched firmware from a USB stick, then download a channel list from the Blade Server.
              If using a CS server, you will most likely have to pay (CS access is not bundled) and then enter the details on the box, but that is easy.
              • DAVHAY77
                • Dec 2010
                • 7
                #157
                Who does the Blade compare with the Dreambox
                Who does the Blade compare with the Dreambox?
                Is this Blade 7000 worth buying?.
                • lincsat
                  • 1228
                  #158
                  It's one of the better closed source boxes. Obviously not as versatile as an open source box like the DM or Vu+ boxes.
                  • DAVHAY77
                    • Dec 2010
                    • 7
                    #159
                    Thanks.
                    • trauma
                      • 74
                      #160
                      What do you mean by closed source ....
                      You do know that the BM7000s is not a Linux receiver.
                      • wes001
                        • Feb 2011
                        • 11
                        #161
                        Originally posted by ub26
                        Hello
                        hey im having a few problems doing this i tried it a few times but had no joy, should i be getting a 7 day epg for the likes of sly sports if done right?
                        thankd for your help......
                        • dadon123
                          • 34
                          #162
                          here is the newer update dated 25/04/11:
                          BM7000s-122p-25-04-11.zip
                          • redondo5
                            • 277
                            #163
                            Most important part of new firmware is to download channel list for your area from blade online menu option, then select normal db option instead of default. Once this is done you will have 7 day epg at the end of every favourite group, just select it and keep on it for 1-2 mins
                            • trauma
                              • 74
                              #164
                              It's only important if you have a fixed dish setup for 28.2e, but it's not much use for a motorized sat setup though.
                              • tubs
                                • 420
                                #165
                                a great box worth buying would like a twin tunner to come out and may a biger memor to hold epg but maybe usb stick may sort that promblem out later very easy to use and will soon be amuch sort after box leaving dreanbox way behind o much netter to use a big thumbs up to blade
