Finally had chance to get the Clarke-Tech ET9000 plugged in this morning and first impressions are this one's looking very good already!
I've ended up flashing it with the OpenPLi Beta image from 17/12 as the original image works fine from the little I tried but it's got none of the goodies available via downloadable addons and the very latest PLi 2.0 Beta is not quite there yet, I did give it a quick blast but still a few bugs in this one just yet to what you might call production ready, so for now OpenPLi Beta from 17/12 it is!
Real easy to flash this one, just download the OpenPLI Beta image from 17/12 (available in downloads section now), unzip the et9000 directory and transfer it over to a USB stick, make sure the et9000 directory is in the root of the USB stick, then stick it in the front port of the ET9000 and turn the power on.... The receiver should see the USB stick straight away and will scroll across the image type/date then ask if you want to flash it and promot you to press OK on the front of the receiver if you do.... So press OK and away it goes.... Couple of mins later or so and the receiver will finish then auto-reboot, you can remove the USB stick now and the usual PLi startup wizard will load up, happy days!
I setup my config here just like I do for the VU+ DUO (it's Enigma2 and PLi so it's exactly the same setup for this part). I set this for DVI (it's HDMI actually but just select DVI, unless using scart connection of course!). I set Tuner A for DiSEqC Motor using USALS and Tuner B for single fixed dish on 28.2/5 East. I don't bother with parental controls etc. but set these to suit yourself.
So that's it, base install is ready and you are ready to add some extras. Here you could choose to scan for channels etc. if that's your thing, but for me it's just not worth it, I fired up Dreambox Edit, loaded in the latest Catseye settings, set the IP address up of the ET9000 in Dreambox Edit, again it's standard E2 here so just find this by going to Menu > System > Network > Adapter SEttings and here you can find your IP address, I changed mine to use a fixed IP but you can use DHCP as well, whatever best suits your needs.... So then used Dreambox Edit to send the channel settings over and within seconds they were on the ET9000 and Enimga has reloaded, job done!
So with channels loaded on now I checked out a few stations on various satellites, no problems at all, only FTA channels at this stage and as expected just like the DUO it defaults to Tuner B for the 28.2/5 stuff and the rest using Tuner A via the motor.
Next thing I did was download CCcam from the PLi Addons Menu which is Menu > Plugins > Green > Softcams > CCcam 2.2.1 and install, once this is done it will automatically be set as your standard softcam to use so all you need to do is FTP in and add your C line to CCcam.cfg which is in the usual place on and Enigma2 receiver, in the /etc folder. You can of course also add config settings for the two card readers built into the ET9000 if you want, I've not tried this part yet so I'll come back to that at a later date. After this I tried a Pay channel that I know is valid and sure enough it clears great, no problems what so ever!
Next up tried the PIP (Picture in Picture). To activate this press the blue button. The blue button is important to PIP as this is what controls what Zap (channel change) is controlling, either the main picture or the smaller second picture and if PIP is enabled or disabled. I had a play around here flicking from one channel to another and from main picture control to second, no problems here again at all, it just works including two channels via CCcam at the same time! Once slight thing I've noticed is it won't show an HD channel in the second smaller picture, weather via CCcam or FTA, so it's SD only for second picture at the moment, the main lager picture can be HD no problem!
Next stage once happy that was all working as it should was to switch the thing off and inscrew the case ready to fit a 1TB HDD I've got here, it's a brand new Samsung HDD that's never been plugged in until today. The pictures below will show the receiver with the case off (actually pulled back, no need to take the whole thing off, just slide it back one you've removed the 5 screws
(3 at the back and 1 each side). You can see the HDD caddy in the pictures, this is already fitted inside the ET9000 and is easily removed by removing 3 more screws. Once that pops out you can fit the HDD inside it and screw it to the caddy using the 4 screws provided (they are in with the remote and batteries etc. in the ET9000 packing). Now fit the whole thing back in and screw it back into place with the 3 removed screws, then connect the SATA connections from the drive to the main board using the SATA cable supplied with the receiver, it's just a standard 4 pin power sonnection and SATA cable which slot into place using the supplier lead, so you can use and standard 3.5" SATA drive. Finally screw the case back on buy just sliding it back into place and putting the 5 screws back into place, job done!
Net thing to do then is initialize the HDD. So boot up the ET9000 again and once done press Menu > Setup > System > Harddisk > Initialization > Red > Yes and this will start doing the job, depending on the size of the drive this will take a few seconds to a few minutes! Just leave it be for a while and go and make a cup of tea, once you get back it'll be done and ready!
Once that's done I tried a quick recording of a single channel, recorded an HD channel that's working via CCcam for a few seconds, then tried playing back, no problems at all. I have not gone any futher with testing recordings right now.
Next thing then was to setup an EPG. From the PLi Plugins (Menu > Plugins > Green) select extensions and install both the xmltvimport and xmltvimport-rytec. It's best to give the ET9000 a restart at this point. Once loaded again got to Meu > Plugins and you should now see EPGImport on the menu, select that and alter the settings to how you choose. I Chose Rytec UK XML TV from Sources then pressed yellow to do a manual update. That begins then after a while will complete. Now exit all the menus and give a long key press on the i button, select Graphical Multi EPG, select the channel groups you want and if all has gone well you should now see a fully populated EPG, great!
That's about as far as I've got for now other than download a few skins and try them out, I've not tried out any other plugins or media playback etc. will give more a go when I get chance, will be over the course of the next few days or so now most probably! More to follow...
My honest thoughts on this one, it does exactly what you'd expect at the moment, if you are interested in the extras over the DUO like PIP and tuner loop-through per tuner plus the fanless operation then this has to be considered now, and with some good support from PLi already and only likely to get better it does look a real contender just like the DUO was this time last year! Contact Sat-Shop.co.uk if interested in this, they are in stock and available now and I'm sure a little demo can be arranged for anyone that wants to just see this in action before making your final purchase!
I've uploaded the first 4 photos as attachments on their own then included the rest in one zip attachment because we are only allowed 5 attachments per post. Just give me a shout if you want the pics and can't see the attachments for any reason.
