I had a major problem with my motor not moving after a reflash and tried everything suguested from other's around and nada, i had the same problem as you with connecting wire to LNB and no power light and nearly gave up, but started to play around with the tuner config and back up and running.
What are your tuner settings ? is it set up correct ? lnb connection, voltage type etc.......
