dish probs again lol
  • owenb
    • 703
    #16
    no mate left it for a bit going to do it now tho
    • 00360362878
      • Mar 2010
      • 488
      #17
      Originally posted by owenb
      am i right in thinking that i can go to simple and positoner now and do my long and lat then? or ido i have to fine tune each sat m8?
      No mate you dont go into positioner.
      In tuner config enter all the settings as Westkills guide exept of coarse long lat because that needs to be your long lat, make sure you enter that correctly.
      Your setting up advaced (not simple)
      Under advanced is the sats you are going to use Ie when you first set up you did it with sat as 28.2E then you press ok to save, that will take you back to alps tuner, go back in to config and scroll down to sattelite scroll left or right to the next sat you want to use then ok to save so on and so on. once you have configured all the sats you want to use. that is it in tuner config.
      Zero and reset your dish, select a channel BBC 1 or whatever your box should drive the dish to 28.2E then you need to tweek your dish manually to get your best signal, then sellect a channel on a different sat it should drive to that sat and then u may need to do a little more tweeking. It will work but be patient mate.
      Good luck
      • owenb
        • 703
        #18
        cheers mate thats brill ill have to give it a go in the morning now as its getting a bit dark and windy and knowing my luck ill fall off the ladder will let u know how i get on in the morning
        • 00360362878
          • Mar 2010
          • 488
          #19
          I would print off westkills guide mate then you have it for another time, also I forgot that when you go back each time you choose the next sat scroll down and choose 1lnb, that will then fill in the rest for you mate.
          • owenb
            • 703
            #20
            no worries, gave it a go was feleling brave have lost absolutely everything now i reset ,y dish to zero cant even get 19.2e now ,somethings gotta be faulty. i can manually locate 19.2e from positioner setup but everytime i go to the channel list and select arte or something like that the dish spins and doesnt pick anything up at all...... seriosuly thinking about getting a pro out htis wek to have a look at it now
            • Fergal
              • 1007
              #21
              Yes you can do just that then use the sat finder option and or upload a channel list.
              • owenb
                • 703
                #22
                ill give it a go tomorrow if i cant do it im so pi**er off with it im going to ring the local "professionals" and get them to do it the mrs is ready to kill for the amount of time i have spent ignoring her and the kids faffing about with it
                • owenb
                  • 703
                  #23
                  just had a thought could the lnb of moved in the dish ? i just noticed this morning that ait looks to be on a different angle to what it used to be. also contermplating change the single lnb for a quad when i take the dish off icecrypt 0.1 looks the best value for performance found one for ?16.99
                  • dick b
                    • Jun 2009
                    • 2462
                    #24
                    any universal lnb will be ok be it single,twin or quad.in a motorised setup it should be set to zero skew.
                    • owenb
                      • 703
                      #25
                      ok cheers mate i just called the local pro and hes ame out and said the dish has gone out of its arc ( im guessing with the wind) will need realligning so going to get him to do it and fit me new lnb at the same time. any ideas how much they should charge for fitting this lnb and reallignment i had a quote just think its a bit steep
                      • dick b
                        • Jun 2009
                        • 2462
                        #26
                        no idea mate If I cant do it myself it dont get done.
                        • owenb
                          • 703
                          #27
                          fair enough buddy wisk i could dop it
                          • mark8393
                            • 2305
                            #28
                            who quoted you? was it AJL?
                            • owenb
                              • 703
                              #29
                              yes mark the local "pros " are ajl m8
