PcEditor V1.2.46beta12, Help please
  • jud1255
    • 34
    Please help regards updating channel list using PcEditor V1.2.46beta12 by jondoe
    I CANNOT UPDATE CHANNELS
    I can download via ftp but cannot update via usb or ftp
    Im not sure if its my pc that?s at fault or me !.
    I Cannot send any channels back to ipbox
    Here?s whats happening:
    Pc usb connected to ipbox via USB to B (printer cable)cable
    Pc to Netgear Router wireless
    Netgear Router to ipbox via Ethernet cable
    PcEditor/options/settings/receiver = ipbox ip-ad 192.168.0.4
    Ftp u/n root / ftp p/w relook web u/n relook web p/w relook
    USB database download-local directory 192.168.0.4 ?start = usb is not connected try again
    Please note I have previously installed and updated image using flashtools vers 102 and yes installed USB driver
    Ftp database download ?ipbox?-local directory -192.168.0.4-start = DOWNLOADS CHANNEL?S
    Using FTP is ok to download Channels from ipbox !
    Then I save file as db5 on desktop
    Now when trying to upload via either USB or FTP I am getting the
    ERROR
    Ftp database upload (ipbox9000)
    Upload from file
    Locate and select db5 on desktop
    Start = if you upload this db file, existing db will be deleted do you want to continue ?-YES
    Upload progress stays empty and then after 2 minutes says error
    Saying error saving database - ok
    Then again error saving database ? ok
    I have tried turning off and back on ipbox as if booting and still the same errors
    The usb is not recognised at all and the ftp only downloads and not uploads
    I should be able to send new db5 file to ipbox via pceditor YES ?
    If not
    Using such as flash fxp where would I drop db5 file ? and into which folder on ipbox ?
    Hope you make sense of this, thanks jud
  • sotiris70
    • 31
    If you want to use flashfxp, ftp the db.dat to your box in /var
    and name file: db.dat.edited
    and reboot for changes to take effect
    • jud1255
      • 34
      channel list
      thanks yes i will do that.
      i just had a look in var folder,via core ftp
      there is already several files in the var folder eg hotbird eutelsat intelsat etc .
      do i delete all these files first.
      I have never installed channel list , i have got channels and sats by searching on ipbox menu service searching etc.
      I have dowloaded channels via pceditor , edited channels eg itv hd for sound and saved file on desktop db.dat.edited
      do i now drop /drag this db.dat.edited to var folder will it remove previous files automatically.
      thanks jud
      • catseye
        • 388
        Hiya
        As a suggestion have you checked all the connections on the cuberevo/ipbox as sometimes my cat 5 cable becomes loose at the back & has to be pushed in firmly
        Also try using DCC v2.95 (the Dreambox FTP file) to connect to your box as it will show up if its not connecting, or passwords wrong etc
        on pceditor the software can be a bit tempermental (i know its only beta) & when i select FTP upload database cuberevo, tick upload database from file, file & select which one (again ive always used a complete file (@otheitis42E-30W) ive edited not a dat.bak one) open & start
        Then message of rewriting etc & rebooting box for new settings to load etc -takes approx 10 secs
        Dont forget factory reset will wipe all your old channel settings otherwise your box may run slow!
        Vu Duo & Channel Master 1.2 meter dish located in middle england
        • jud1255
          • 34
          Originally posted by catseye
          Hiya
          thanks cat5 is ok ftp is ok,
          i was originally trying to upload via pceditor , but no longer .
          now i am uploading using core ftp this is working.
          i now need to know
          which files in var folder to delete before sending new db.dat.edited to var folder
          thanks jud
          • jud1255
            • 34
            ERR 79
            Oops, I deleted some sat files in var folder via Core Ftp, now I got the ERR 79 message on boot up.
            Does this mean I now have to re-flash with latest image eg nlb 8421.
            • aftermath
              • 4345
              yep, reflash your box,, as youve deleted files your box is needing to work, only takes about 15 mins anyway, and if you backed up you files, keys, scce, database you will be fine.
              best to start again m8.
              Lesson learned, always back image up before tinkering.
              • catseye
                • 388
                Hi Jud1255
                I think ive cracked it m8
                Open up pc editor-select new or blank in top left hand corner
                Download database to pc editor
                FTP database download appears-tick open download DB file & start-
                within a few seconds channel settings from box appear on screen
                Amend database
                Select upload database to Relook -box appears FTP database upload Cuberevo
                Dont tick upload database from file
                Start
                Message appears -re existing DB will be deleted -continue -yes
                Message to reboot box for settings to update
                Reboot box & new settings should appear
                Then if you wish to save your new file -file save as & select location
                Ive just used this to update & add ITV HD to list- although cant get no signal at the moment -could someone check if its still on air!
                • aftermath
                  • 4345
                  hi catseye, ive never managed to get a picture on ITV HD at all yet, i know some peeps in certain areas do get a picture at certain times.
                  Glad you got sorted with the Database editing and transfering, well done m8.
                  • catseye
                    • 388
                    No problem m8 -its a big learning curve getting used to this box!
                    • jud1255
                      • 34
                      Hi Jud1255
                      Amend database
                      Start
                      im ok upto here, then mines just hangs b4 the error message appears.i dont see the following:
                      Ps icocked up last night ive gotta now re-flash mine which ill be doin in the next hr or so , will keep u posted
                      • catseye
                        • 388
                        ps i forgot to say ITV HD test card was on last week & watchin Champions League footie -This week according to Tv times theres no HD content on this station
                        I wondered whether ITV HD are tinkering at the technical end so as to allow those with a Sly HD box to watch as & when?
                        Although King of sat still shows same frequency etc
                        • jud1255
                          • 34
                          i had test card on yesterday but no sound , untill i cocked up but according to freesat theres nowt on now untill 20th dec
                          ww.joinfreesat.co.uk/index.php/freesat-channels/itv-hd-schedule
                          • catseye
                            • 388
                            I would reflash your box in case something has gone awol & start again
                            My settings are as follows if this helps & its connected via router
                            Options,PC Editor settings,General -no tick in no ping when accessing receiver
                            Dyndns addy blank,
                            Use dyndns box- blank,FTP telenet user name =root, FTP/Telenet password =sifteam, webuser & password both blank
                            Manage receivers name IPBox9000, Type Cuberevo
                            Receivers -Cuberevo -Ip Addy is same as box ip addy,
                            check this as sometimes when box reboots it gives itself new addy- check under menu, advanced set up,ip set up & type-mines set to Auto DHCP
                            Try DCC program to confirm all is connected etc
                            When youve sorted that can you sort out enigma 2 in flash with various cams & plugins working please!!
                            • jud1255
                              • 34
                              Dyndns addy blank,
                              cheers, i will try later cos u do have different settings eg p/w & u/n although mine must be connected to enable downloads from box.
                              I dare not even think about enigma looks far too difficult 4 me.
                              i presently have nlb8421v1.110, which im about to re-install but i see abcom just updated to R8630 could i put this straight on, would i benefit out ?
                              i want to veiw english films on as many sats as pos 30w to 42east
                              which are you using,
