Cuberevo addons / plugins
Myepg version 0.2.4i
Kool plugin to give you full working epg on sly UK and Italia.
on NLB image ftp the sh4 file to /tmp folder and rename it too pack.tar.gz then go into panel and install it from there.
0.2.4h
- Fixed missing long description in sync
Fixed epgdb and customs paths
0.2.4g
Fixed crash on standalone importer
Fixed UI update with import and web download
Fixed possible crash in csv import
Fixed skin selector
Added similar events in event info box
Fixed aspect ratio with pillar box and 16:9 stream
Fixed aspect ratio with zoom function
Fixed name set in scheduler
0.2.4e
Added epgdb integrity checks
Added channel aliasing support to epgdb
Changed epgdb data insert
Added alias utilty
Added importer utility
Fixed memory management and system stability in downloader
Other small memory fixs
Added direct access to /dev/commander
Removed scripts in home folder
Added an integrated http client
Added skin selector
Added high visibility skin (thanks to ikbennico)
Added import features to downloader plugin
Reorganized makefiles
0.2.3
Fixed crash in grid view if there are an empty group
Added i18n support (with italian translation)
Fixed config window look
Fixed different √ button for 91HD series
Added menu (start sync, start downloader, configuration)
Added live preview box (thanks to Pippo9000)
Added support for sky uk (untested)
Added text justifying
- Other small fix and ui enhancements
Added standby management in downloader
0.2.2
Added 'colors.scheme' file in skin folder
Added '+/- 24h' and 'go to now' buttons in grid view
Fixed configuration and data integrity checks on application start
Added message box (used in several point of code)
Added configuration menu
- Added now time marker in grid header
Changed buttons images
- Changed skins folder organization
0.2.1
Added fav checks on plugin start. If there are no favs the application exit gracefully
Added 'scheduler remove' function. Press "Rec" or "Ok" button over a scheduled event.
Added 'sync_groups' key in configuration.
Now you can set how groups sync with the internal db
0.2.0
First "official" release
here is a skin for myepg.
0.2.4h
0.2.4g
Fixed skin selector
0.2.4e
Added alias utilty
Added skin selector
0.2.3
0.2.2
0.2.1
0.2.0
