Cuberevo addons / plugins
  • aftermath
    • 4345
    #16
    Myepg version 0.2.4i
    Kool plugin to give you full working epg on sly UK and Italia.
    on NLB image ftp the sh4 file to /tmp folder and rename it too pack.tar.gz then go into panel and install it from there.
    0.2.4h
    - Fixed missing long description in sync
    Fixed epgdb and customs paths
    0.2.4g
    Fixed crash on standalone importer
    Fixed UI update with import and web download
    Fixed possible crash in csv import
    Fixed skin selector
    Added similar events in event info box
    Fixed aspect ratio with pillar box and 16:9 stream
    Fixed aspect ratio with zoom function
    Fixed name set in scheduler
    0.2.4e
    Added epgdb integrity checks
    Added channel aliasing support to epgdb
    Changed epgdb data insert
    Added alias utilty
    Added importer utility
    Fixed memory management and system stability in downloader
    Other small memory fixs
    Added direct access to /dev/commander
    Removed scripts in home folder
    Added an integrated http client
    Added skin selector
    Added high visibility skin (thanks to ikbennico)
    Added import features to downloader plugin
    Reorganized makefiles
    0.2.3
    Fixed crash in grid view if there are an empty group
    Added i18n support (with italian translation)
    Fixed config window look
    Fixed different √ button for 91HD series
    Added menu (start sync, start downloader, configuration)
    Added live preview box (thanks to Pippo9000)
    Added support for sky uk (untested)
    Added text justifying
    - Other small fix and ui enhancements
    Added standby management in downloader
    0.2.2
    Added 'colors.scheme' file in skin folder
    Added '+/- 24h' and 'go to now' buttons in grid view
    Fixed configuration and data integrity checks on application start
    Added message box (used in several point of code)
    Added configuration menu
    - Added now time marker in grid header
    Changed buttons images
    - Changed skins folder organization
    0.2.1
    Added fav checks on plugin start. If there are no favs the application exit gracefully
    Added 'scheduler remove' function. Press "Rec" or "Ok" button over a scheduled event.
    Added 'sync_groups' key in configuration.
    Now you can set how groups sync with the internal db
    0.2.0
    First "official" release
    here is a skin for myepg.
    • aftermath
      • 4345
      #17
      PC editor Latest 1.2.50
      - New: Show/hide separate columns from channel list header context menu
      - New: Added several fields from channel database to channel list
      - New: Support for new OEM receivers from Sezam/MADTEK/VIZYON
      - New: Toolbar button "Check for update"
      - New: Ukrainian language file
      - New: Added a few setup languages
      - Updated: Arabic language file
      - Fixed: Sometimes panic after trying to flash an image via ftp from hard disk
      - Fixed: Problem with Webif when wrong user/password was set
      - Fixed: Export name for WebEPG is now all lowercase
      - Fixed: Channel database download: Not changing "Local Directory" when changing receiver
      - Fixed: Truncated values for symbol rate and frequency when importing KingOfSat and
      Satellite.xml.eu transponders for channel database 1.20 and lower
      - Fixed: In-place editing of channel list was not possible for channel databases from CubeCafe receivers
      - Fixed: Crash after changing favourite sort order and clicking "Yes" on message box for saving sort order
      plus a few more minor fixes
      • gigetto_p
        PC Editor 1.2.51
        Buongiorno a tutto il forum questo ? il mio primo post
        Changelog PCEditor 1.2.51, 10.05.2009:
        - New: Support for new channel database R9274 (Firmware 9341)
        - New: Create new database R9274
        - New: Reboot receiver from toolbar
        - Fixed: Several problems hiding/resizing channel list columns
        - Fixed: Sorting the channel by several columns list was not possible
        - Fixed: Problem searching channel names for database revision 8118 and later
        - Updated: Polish language file
        ciao
        • ABones
          #19
          Green click v1.0
          Name: Green Click project v1.0 pilot
          Author: Andrew Bones Copyright ? 2010.01
          Program type: script/plugin/FREEWARE
          Hardware compatible: Cuberevo/Ipbox/Sezam
          Software compatible: UFM, PGI, SifTeam, NLB, DGS, ABCom
          Bag report: [email protected] SUBJECT: Green Click bag
          Description: This plugin extends a green button functionality of receiver remote control.
          How install it?
          Action before installation:
          before install the green_click you should rename an existing file "/var/bin/green.sh" to other name.
          For this action you do a next steps: WEB interface->system->Telnet. Enter into the telnet window following string:
          mv -f /var/bin/green.sh /var/bin/green_old.sh
          Installation:
          WEB interface->system->plugins "Install plugin"->Choose file->Upload plugin
          How it works?
          You can press 1 2 or 3 times a green button and get to start 3 different plugin or script.
          How do I join a script or plugin to a button click?
          There is a configuration file /var/green_click/green_click.cfg. This file includes a setting manual.
          How uninstall green_click?
          Uninstall action: WEB interface->system->Telnet.
          /var/uninstall/green_click_uninstall.sh
          mv -f /var/bin/green_old.sh /var/bin/green.sh
          Where from can I download it?
          URL1: http://rapidshare.com/files/33613853...lick_v1.tar.gz
          URL2: Hotfile.com: One click file hosting
          Enjoy.
          • ABones
            #20
            MGCAMD 1.33 OEM for original images DGS or ABCom also Sifteam
            Name: MGCAMD 1.33 OEM for original images DGS or ABCom also Sifteam
            Package built: Andrew Bones 2010.01
            Software compatible: SifTeam, NLB, DGS, ABCom
            Description: MGCAMD 1.33 OEM for original images.
            What is interesting in this package?
            1. Very easy installation and setup.
            2. Include a restart script of mgcamd
            you can start it thru script.plugin (not include here) or WEB interface-> System-> Telnet
            /var/bin/scrplg-mgcamd-restart.sh
            3. Don't need any extra action for get it started after receiver restart.
            4. Include a script for creates new newcamd.list file - it works: WEB interface-> System-> Telnet
            /var/bin/clrcamd.sh "CWS_KEEPALIVE = 600"
            CWS_KEEPALIVE = 600 - you can change this value on your requirements.
            5. Include a script for add new lines into newcamd.list - it works: WEB interface-> System-> Telnet
            /var/bin/nlcamd.sh "CWS = sharserv port username userpass 0102030405060708091011121314"
            sharserv,port,username,userpass - it's yours values.
            don't forget restart a receiver.
            WHAT WE HAVE AT THE END - FULLY WORKING MGCAMD IN FEW MINUTES
            How install?
            WEB interface-> System-> Plugins "Install plugin"-> Choose file -> Upload plugin
            How setup /var/keys/newcamd.list?
            1. /var/bin/clrcamd.sh "CWS_KEEPALIVE = 600"
            2. /var/bin/nlcamd.sh "CWS = sharserv port username userpass 0102030405060708091011121314"
            3. repeat step 2 if it's needed.
            Uninstall: WEB interface-> System-> Telnet.
            /var/uninstall/mgcamd_uninstall.sh
            Where from download it?
            URL1: http://rapidshare.com/files/33675840...133_oem.tar.gz
            Enjoy.
            • maguvu
              #21
              I have been using Gemini images for Dreambox 500s too long I get confused with amount of work you have to put to get ipboxes run the way you want !
              • sindreengen
                • Dec 2010
                awesome, thanx
                • sadig
                  • Aug 2011
                  thank you
                  • remahsharaf
                    • Nov 2011
                    i have NLB Img and i have problem with translation on Amos, this egp solve this problem or not?
                    • zilvinas
                      • Feb 2012
                      • mikee81
                        • Feb 2012
                        thx, seem to work great
