when i recive a cline how will it cum and how will i upload it to the box ? will it cum in note ba then simply drag onto usb then on to box and everyfin works ???
28.2 e sky uk channel list openboxe s9
Receivers----------OPENBOX X3
Skybox M3DM528 - PliJadeDM500s - PliJadeTechnomate TM500 - UR--------------------------------------------------------
If you like my posts press the "Thanks" button to show your appreciationComment
can you recommend a decent server to use theres alot on google i am just wondering wots the best im new to all thisComment
instructions
here u are instructions mate...it is very easy!!! RegardsAttached FilesComment
thanks for them i still seam to be having problems my box is not picking up skysports one or chanels sutch as that it has a lot of chanels wot say this $ch-4529 but no name of wot it is any help thanksComment
You should load a channel list that has been organised already. Its much easier rather than scanning and organising yourself.Theres a new one here done by Dumbo http://www.digital-kaos.co.uk/forums...4-11-a-201135/ fair play to him.Comment
Theres plenty good servers around but make sure you ask for a test cline before any money changes hands and don't hand over more than 3 months ???? as some servers are taken down not by choice
Pm me if you need help
KevReceivers----------OPENBOX X3
iv deleted all them chanels upload the new chanel list but it says no chanels and iv reset the box and the sameComment
Put the channel dump file on to a formatted fat32 usb stick, insert into box,
Go to MENU > TOOLS >Upgrade BY USB
Point to MISC Files then arrow down to SELECT & Upgrade and press OK,
Press green button to add TP_PROG.dbs
Press yellow button to copy the file
Reboot when finishedComment
Use these files you shouldnt have any further problems
tryed it i flashed it with the new version but when it comes up it says not found do i have to scan for chanels the try it or wot its really anoyingComment
Firstl before you do a reflash you must reset you box to factory defaults from within the menu.
Yes scan the sat to pick up the channels the upload we put up for you will just reorganise them.
To make things easier for you if someone could upload a dump file, i can do it tonight for you but hopefully someone may do it sooner
So do it in this order
Reset to factory
Upload firmware
Scan satelite
Upload tp progs
This works perfect every time so you shouldn't have problems
hi kev when i upload the dumbo123 file do i have to rename it coz when it comes to uploaden the firmware it works but when i try the chanel list it says not found when you go to info thanksComment
