thanks for the download
28.2 e sky uk channel list openboxe s9
Quick google and i found this
How to manually add a TP to your OpenBox (easy)
This one is very simple to do, anyone can do it.
2 ways you can start:
1. Move the dish to the satellite you want to add a TP to.
-or-
2. Just go to the tp list and flip thru the satellites. OpenBox will automatically move the dish as you change satellites.
Either way here is the proceedure when you are on the sat you want to add to.
1. MENU > INSTALLATION > TP List.
2. Look and make sure you are on the correct satellite. If not use the < and > arrows to flip thru. If you were already on the satellite it should be the one selected alreadyu.
3. Press green button to add.
4. Type in the frequency, then arrow down to symbol rate
5. type in the symbol rate, arrow down to polarity. Use < or > arrows to change polarity.
6. Arrow down to save, press OK button
To scan the TP:
1. Press blue button on remote for Search
2. Either press ok and it will search, or set the options if you want such as FTA only, TV/Radio and Network search. I just hit the ok button as the defaults are what I want with a manual TP scan.
Frequency: 10847
S/R: 23000
Polarity: V
FEC: 8/9
bbc one and bbc hdLast edited by hooley; 10 June, 2011, 21:02.Comment
i knew i'd be asking a question sooner rather than later!
i cannot get the channel list to work... it dumps & upgrades ok, and resets to factory defaults but never any sly channel numbers.
using openbox s10 firmware chds2-11-05-20-08b5cm chipid 00ea
my only thought is does the usb data have to be formatted in fat32 as my computer runs ntfs, as mentioned on one thread it stated fat32.
any help/guidance would be appreciated
My USB stck that I use is fat32. You should get a thing popping up on screen when you insert your USB stick in the box. Well I do on my s9 ,I'd say it's same with s10i knew i'd be asking a question sooner rather than later!
Yes, a usb inserted message does appears.
i did a firmware update with it.
aso i have done the usb dump & usb upgrade which it says is ok.
it even reboots itself sometimes... but the channel numbers are always 1 to 0742, sometimes all the channels are deleted.Comment
Can one of you guys upload a channel list for norn ireland please and save me the hassle as i have been given this box by a complete numpty to load for him i have installed the firmware and scanned the channels okay but it is the fact that i cant find a channel editor and would have to manully update the list...Comment
Hi
This is my channel list for uk, this was after I put on the May firmware HDS2_CMTS_Europe the one you had to make sure box original and not a clone.
Anyway there after I sorted channel list so upto date up to couple of days ago.
When I took box back to me sis found was causing reboot sky news needed to be deleted to stop reboot otherwise its ok. So you may have to delete that channel once put on, If I go to me sis IL put on usb so its without problem channel or you should be able to edit it with an editor before putting on. Its channel 27 in the sports favourites.
If anyone uses it just let me know what you think.
Got the full dump as well but not uploading just in case someone uses it on a clone box and messes it up, if anyone wants it let me know.
Edit: Have now uploaded the channel list without the problem channel, just deleted it with editor.Attached FilesComment
Thanks for the listings..I have just checked and i have a clone the chip id is 0100 and the listings you sent are not loading but thanks for uploading them mate..could somebody post a link to the latest clone safe image as i can't load some of the hd channels as the receiver wont see the new transponders..Hi
Edit: Have now uploaded the channel list without the problem channel, just deleted it with editor.Comment
HiThanks for the listings..I have just checked and i have a clone the chip id is 0100 and the listings you sent are not loading but thanks for uploading them mate..could somebody post a link to the latest clone safe image as i can't load some of the hd channels as the receiver wont see the new transponders..
0100 does not mean its a clone its the digits after, how did you check for it. Did you do a visual check as well see what color card reader its got.Comment
the ccid only shows 0100 and nothing after that and the card reader is just black from the outside but i will open it and look what colour should it be?Comment
