Has someone the issue, that in the cccam option the status is always "Login", but with my other dreambox and the same cccam.cfg, there is no problem ???
Hi there.
I upgraded firmeware to latest; after this the openbox s9 hd pvr would hang after a few seconds.
I then tried to upgrade firmware again; though maybe better luch second time. No good idea. Now Openbox hung while writing firmware.
After this; I starts loader 5.02 -- then i get Err: 0x71
Any other solution than writing other firmware via null modem cable? Any secret hard reset functions as on a mobile phone ("hold in this and that button.." )?
Btw; googling around; I found my menu look like S10-menu -- not like S9... descriptions howto upgrade S9 via usb does not fit my menu (not that it is possible just now)
This may very well be the only solution, is your box clone or original?
hi everyone, im located in australia im trying to chase plug ins and fimware to correct the no update problems as my cards wont update, i was wondering is this the latest openbox firmware for the openbox hd 10 that will give me the plug ins and the firmeware to fix the problem on my openbox hd 10 model, also is this the firmware jackal and the other members are talking about, thx david nsw australia
Can someone here advise which firmware will list MEASAT in the satellite list of my S10HD? I had 1011 firmware updated (from 0524 version) but can not see MEASAT too! Did I accidentally updated the firmware for the wrong region if there is such thing?
Should this firmware work with the S9, as when I tried it only the network and USB functions were available. Every other setting in the menu was blanked out....any help much appreciated.
