stuck on "on"
  • mept1
    • 346
    #31
    I,m in the same boat for a few months....mine,s defo a clone,..looks like i have one of each... been told jtag is the only way forward ...there a spanish manual/guide... 4 wires to solder see guide attached....got from portbhoy.
    • southpaw
      • 2233
      #32
      cheers for the guide mept (although my spanish is as good as me soldering ), i was under the impression mine was genuine , have you tried the methods above with the repair tool / serial cable ?
      • mept1
        • 346
        #33
        oohh..... yes. ask dubdave,..i,m like you was days on it,...i,v flashed evey box from sv1 to dbox2,s.....this one,s got me stumped!.....i no jtag needs to be done....but i,m not desperate yet.
        • southpaw
          • 2233
          #34
          giz a shout when your desperate , or set 8 hours aside as i did , then you will be beyond desperate
          • ukwomble
            • Jun 2011
            #35
            Hi,been having exactly the same problem as you today and got to the stage where box was going to be thrown out the window!!!
            Tried one final thing that worked so hope this helps you also.I used the pvr800 tool as has been talked about already but I changed the bit rate settings from 115200 down to 57600 in the drop down menu and it re-flashed on first try!!!
            Hope this works for you also.
            • southpaw
              • 2233
              #36
              Wow. Nice info womble. Glad you got your unit back to life. My 1st stuck on on box mobo is on route to hongkong but a customer has just sent me there's with same issue. Will give this a bash later in week. Many thanks for sharing mate
              • hooley
                • 470
                #37
                Might give this a bash also.
                • southpaw
                  • 2233
                  #38
                  Let me know if it works if you do it before me hooley and I likewise
                  cheers mate
                  • ukwomble
                    • Jun 2011
                    #39
                    No probs guys,just hope it works for you aswell and it wasn't just a "fluke" on my part
                    • mept1
                      • 346
                      #40
                      No good for me..but pleased for yourself....
                      • ukwomble
                        • Jun 2011
                        #41
                        I'm sure your doing it as has been explained but just in case here'e how I got it working:
                        Connect box via Null Modem Cable(box switched off)
                        Run pvr800 tool
                        Change bit rate to 57000
                        Browse for new image,I used the latest european firmware
                        When all that was done I just clicked on next,switched box on as I did that and hey presto it ran through the burn process.
                        The only other thing that I remember doing was I checked my port settings using control panel/system/hardware.I did notice that parity on pvr800 box was set on "Even" yet on my port(port 1 in my case) it was set to "None" so I also changed the parity setting on PVR tool to None also(no idea is this makes any difference as I'm by no means a techie!).
                        • the man
                          • 1660
                          #42
                          for s9 untick bootloader , for s10 tick it , if no luck uplade the s10 f/w on the s9 then reload the dump via the remote. worked for me
                          • mept1
                            • 346
                            #43
                            Run pvr800 tool
                            Thanks for taking the time to explain.......tried every which way since march..no go for me...no matter what loader/firmware combination i use or bit rate.
                            • southpaw
                              • 2233
                              #44
                              No Luck for me either , thanks for the suggestions tho womble ,
                              It seems the box is unable accept a connection , as the prompts are the same as when the null cable is attached to nothing
                              • sweto
                                • 51
                                #45
                                try to check defective ld7550bbn in the psu
                                change it if no reading
