after burning this software both my boxes are only able to run in 480i and 576i resolution, no option to choose anything else...
anyone else had similar problem?
hi michalsw,change your settings in tv system,video resolution=1080i,aspect mode=auto,video out=yuv,digital audio out=lpcm out, this should give you full range
Hi my box has just come this morning,
it still has the original fw on,
im not getting any hdmi output at all,
my T.V. is 720p, I have followed your guide with 720p as resolution
but still no go.
The hdmi cable is working fine, it haas been tested with my xbox360.
I have the Openbox s10. Just bought it a few days ago. The server just won't work. I have an Openbox s10. When I try open the server via Firefox host:13000 it shows a download stream file, so I know there is something there on that port. But when I add the line as described into my CCcam server 2.1.4 it just shows as offline in CCcamInfoPHP and the receiver end gets nothing. It won't see the server as online even though it is!. All I can do with my openbox 10 is watch C lines. I am very disappointed as far as the server side of it goes. Just won't work for me. And I did buy it with intent on using as a server!. Plus when watching a C line as a client it has a habit of rebooting a lot. I have done the port forwarding, everything is correct, server is turned on but just won't be seen as on. Maybe the firmware is messed up?. It's the factory version. and the ID is 3e55:1500 I have to press the 7 key 6 times, it won't work with key 8.
Btw: What is this about Sly cards working in the Openbox 10? How is that possible, the card slot in the box is for Conax. The CI slot I used a Dragon Cam, put in my card it didn't work for me.
