Hope someone can help before i throw this box in the trash, i imported this box direct from china so sending it back is not an option, the other night it was working perfectly then it started to reboot and the display "oN " then Boot and finaly oN, I switched it off untill the following day and it rebooted and was ok for 5 mins and then displayed oN al the time, i have tried to reflash using a null modem cable and both openbox s9 old loader and openbox s9 upgrade tool and all's i get is please reset target (old loader) and (target not connected or target is error status!), have treid switching it on as i press the connect button and pressing the connect button before i switch it on, anyone PLEASE HELP
mow getting message Set stb memory error
You need to use a serial\null modem cable to update the firmware\bootloader as this can not be done via usb and channel freezing is not the problem, thanks anyway handyguy
