Openbox S10 Sky EPG
  • lee11168
    • Feb 2011
    • 217
    #16
    Originally posted by j1mjam
    yh it will as this is the latest firmware with the epg included in it. but as its an .abs file, when you go to the option to flash the dbs file do no select misc on that menu and leave it as the defualt one and the sub menu under it will show the file i have attached and then press start...
    hope that helps..
    worked great thanks
    • lee11168
      • Feb 2011
      • 217
      #17
      am i missing something my lines wont work now
      • j1mjam
        • 23
        #18
        you mean u the channels scrambled? if so u need to replace the information back in box for your server?
        • lee11168
          • Feb 2011
          • 217
          #19
          sorted it thanks
          • southpaw
            • 2233
            #20
            cheers to the op , probably the most organised an complete channel listing i have seen for the openbox , probably have a lot more users if the thread was named correctly
            epg = programme guide (now+next etc)
            channel listing is what this is
            sorry , slightly Anal post i know
            • rabies
              • 34
              #21
              thank you for a brilliant list, i didnt think it had worked, cos' when i pressed the epg button it only showed what was on the chanell i was watching, but if i left the epg up and changed chanells all the epg's showed up.
              • webhead
                • 46
                #22
                hi just put it on my s9 but i only get 1 hour epg and i got latest firmware, and also any chance you could put channels in the same place they are on a sky box, that would be cool ,thanks .
                • nostromo52
                  • Sep 2011
                  #23
                  bit late on this post but Dreambox gone to heaven, so waiting for my Openbox S10. Looking forward to receiving it so i can start playing.
                  • Del_RFC
                    • 37
                    #24
                    Cracking download. Only one problem (and it may not be related) is many of the MTV channels have different audio.
                    Normally when I reselect via the audio button it will save my choice for the next time I return to the channel. With this listing it does not appear to save my choice.
                    • the man
                      • 1660
                      #25
                      is this a ch list or epg ?
                      ie is the epg fully working? is it 7 days ?
                      • taffyjock
                        • Sep 2011
                        • 7
                        #26
                        9. Red Button / Interactive
                        Does interactive work properly on S10 then :S
                        • Manic01
                          • 5117
                          #27
                          Channel list.
                          • Jackal187
                            • Aug 2009
                            • 19
                            #28
                            Having the same issue here, deleted and re-entered, had them restarted from source, but nothing doing... Any help would be great or am i missing something very simple??
                            OpenBox S9
                            • Manic01
                              • 5117
                              #29
                              Make sure they are selected as well as entered then reboot.
                              • Jackal187
                                • Aug 2009
                                • 19
                                #30
                                Thanks for the reply mate, did this but still nothing. I used Hooleys FW update and OP C/List.
                                OpenBox S9
