all sorted now works great thank you
Openbox S10 Sky EPG
my defauf pin has been changed therefore unable to access the menu. any way i can overcome this issue?Comment
epg
why is it still only now and next on epgyh it will as this is the latest firmware with the epg included in it. but as its an .abs file, when you go to the option to flash the dbs file do no select misc on that menu and leave it as the defualt one and the sub menu under it will show the file i have attached and then press start...
hope that helps..
i updates the EPG but it has changed th software to sky box instead of openbox. also i have lost all ma channels only ones i can watch thr free ones..
need help to change it bak asapComment
Download it and see, if it isnt in there then it can be added by yourself and will only take a few seconds to do..
Chances are when you download any channel list the locals ie bbc1 itv wont be set to your region, so these also need changing. But its alot less time consuming adding the odd channel then it is having making a complete list up.If it isn't broke, don't try fixin it..!!!
hi pal will this work on a s11?Hi this is a complete Channel Lisitng for the S10.
it is is almost in sky order.
1. Entertainment
2. Movies
3. Sports / News
4. Music
5. Lifestyle & Culture
6. Documentries
7. Kids
8. HD Channels
9. Red Button / Interactive
10. Shopping
11. Adult
all you need do is extract this zip and copy the dbs file to usb and flash.Comment
