openbox S9 stuck on ON
I've tried using the loader 200c but it's not. why do not they understand? you think that work that work with 200c.only 200c.. but NO ! NOTHING IS WORK!
I've googled and all ali3602 with same problem, no one has a solution.
1000 Threads Target not connect or target is error status! - Google-Suche
no solutions!!!Comment
antiques
that's why you should always have an old pc kicking around with a real com port.I've programmed my s10 with pure garbage and was always able to recover.200c is the only loader that will do that.I've tried using the loader 200c but it's not. why do not they understand? you think that work that work with 200c.only 200c.. but NO ! NOTHING IS WORK!
no solutions!!!
It's been said you can't brick a m3602 based receiver,I am convinced.Comment
there was once an oddball version of the loader that had the include bootloader ticked by default and you had no choice but to load it.Probably a better loader for rookies since most kills are caused by not including the bootloader when updating the firmware.It was less flexible than other versions so I never saved it.It wouldn't fix completely dead receivers so that was another factor in not saving it.Comment
is serial no good? i have usb serial converter but it keeps saying STB sdram is failedI wouldnt have thought the firmware would have made a difference, do you not have a backup of the original? I would probably think trying to get an early firmware release from last year might be the way to go to start with...
I dunno if you have a Null modem cable, if you have a multimeter, test continuity between the pins in each end, if they match on each end then its a serial, if they dont match (they crossover to different pin on other end) then its probably a null modem cable..Comment
I have same issue with HDTVHD 500HD box. Did anyone think of a solution? It's stuck on "ON" - I think it got corrupted following using the FTP on it! Now it won't display "BOOT" either.
Interestingly, it will not sync unless I power cycle, but then it never takes update!Comment
Yes this has a scart connector. Unfortunately, despite trying for hours nothing happens. Tried all different eprom loaders including the one I used to initially put the firmware on! I don't get sync ok unless I turn off box from being on. If I do 'connect' and then power on the box, the sync does not go 'ok'.Comment
