openbox S9 stuck on ON
  • DW190
    #16
    Originally posted by slugworth
    the loader may only work with a real pc rs232 port.
    I could never get it to work with a usb converter.
    I have used a usb to serial converter on both XP and Win 7 without any problems.
    You need the correct drivers for Win 7.
    Take a look here:
    • satman2
      • Aug 2009
      • 36
      #17
      sorry my pc have no rs232!
      its to modern and have usb,hdmi
      usb adabpter work without problem on dreambox800.
      cable is ok
      • slugworth
        • Nov 2011
        • 1064
        #18
        loader
        cable is ok
        that is with a different loader.
        you never know how a different brand loader is going to react.
        get or borrow an old pc and try.
        • satman2
          • Aug 2009
          • 36
          #19
          I've tried using the loader 200c but it's not. why do not they understand? you think that work that work with 200c.only 200c.. but NO ! NOTHING IS WORK!
          I've googled and all ali3602 with same problem, no one has a solution.
          1000 Threads Target not connect or target is error status! - Google-Suche
          no solutions!!!
          • Manic01
            • 5117
            #20
            Its a com error, i have had same issue.
            Downloaded new drivers for adaptor from maplins site and it was ok.
            You need to return the receiver from vendor if not happy.
            • slugworth
              • Nov 2011
              • 1064
              #21
              antiques
              no solutions!!!
              that's why you should always have an old pc kicking around with a real com port.I've programmed my s10 with pure garbage and was always able to recover.200c is the only loader that will do that.
              It's been said you can't brick a m3602 based receiver,I am convinced.
              • BigTUI
                • Sep 2009
                type for access file download
                • slugworth
                  • Nov 2011
                  • 1064
                  #23
                  there was once an oddball version of the loader that had the include bootloader ticked by default and you had no choice but to load it.Probably a better loader for rookies since most kills are caused by not including the bootloader when updating the firmware.It was less flexible than other versions so I never saved it.It wouldn't fix completely dead receivers so that was another factor in not saving it.
                  • patik
                    • Jul 2012
                    Thank you for posting a fix, have a S9 stuck on "on" that got corrupted when I used a corrupted firmware file. Have an old computer with a serial port, crossing my fingers.
                    • brendanmcerlean
                      • Sep 2011
                      • 83
                      #25
                      Originally posted by nibblitz
                      I wouldnt have thought the firmware would have made a difference, do you not have a backup of the original? I would probably think trying to get an early firmware release from last year might be the way to go to start with...
                      I dunno if you have a Null modem cable, if you have a multimeter, test continuity between the pins in each end, if they match on each end then its a serial, if they dont match (they crossover to different pin on other end) then its probably a null modem cable..
                      is serial no good? i have usb serial converter but it keeps saying STB sdram is failed
                      • dougm1970
                        • Mar 2012
                        • 103
                        #26
                        six different firmwares...direct to serial port...using a usb serial adapter...hours and hours trying, following instructions by the letter...turned anti virus and firewall off...still getting the STB sdram is failed...every time
                        • dalwinder
                          • Oct 2012
                          is there a usb to serial null cable? my laptop does not have serial port.
                          • lestasmsc
                            • Apr 2012
                            • 29
                            #28
                            I have same issue with HDTVHD 500HD box. Did anyone think of a solution? It's stuck on "ON" - I think it got corrupted following using the FTP on it! Now it won't display "BOOT" either.
                            Interestingly, it will not sync unless I power cycle, but then it never takes update!
                            • slugworth
                              • Nov 2011
                              • 1064
                              #29
                              it should be the same technique/files as the openbox.
                              Is that the one with the scart connector,or was it the 800?
                              • lestasmsc
                                • Apr 2012
                                • 29
                                #30
                                Yes this has a scart connector. Unfortunately, despite trying for hours nothing happens. Tried all different eprom loaders including the one I used to initially put the firmware on! I don't get sync ok unless I turn off box from being on. If I do 'connect' and then power on the box, the sync does not go 'ok'.
