Openbox S10 Front of Box saying ON ??
  • plevel
    • Apr 2011
    i have the same problem, i will test to resolve problem with rs 232 cable, but searching loader for now and firmware.
    • ultracleaning01
      #92
      Recover openbox with "on" frozen on display.
      Please please please guys try different serial ports don't assume because a serial port on your laptop works with something else that it will work to recover your box. try a different serial port on a desktop pc or a friends pc for example. I tried about 30 times with my laptop suing an expansion card which always works with dreambox but would not complete the handshake with my openbox. used my desktop and voila 2nd attempt.
      • eriklee18
        • Nov 2011
        #93
        why s10 dont hv like other gadgets, if anything wrong just press the factory default hole and it will reset
        • LeonRead
          • Jul 2012
          • 23
          #94
          Hi, everyone:
          Some secret I can tell you , some people clone the chip id as the same as original , If you are not sure, Please do not buy the box . Because all the original manufacture stop producing the S box since march 2012 , the developers stop maintain the code . So many clone box on the market . But I am sure the SKybox F3 is original . You can buy the box instead of S9,s10,s12. For the s10 clone box user, Please recovery the old firmware.
            Originally posted by LeonRead
            Hi, everyone:
            Welcome to DIGITAL-KAOS mate enjoy your stay ...............
            • bodyguard
              • Jul 2011
              • 7
              #96
              Well my openbox is still dead...
              I dit everything to upgrade. flash it with erom repair.
              But nothing changed. :-(. And i don'have a clone.
              When i switch the power on it says On and after 1 , 2 seconds i see
              two green dashes.
              • slugworth
                • Nov 2011
                • 1064
                #97
                clone kill
                I did everything to upgrade. flash it with eprom repair.
                But nothing changed. :-(. And i don't have a clone.
                two green dashes.
                you have to run clone safe firmware.
                I just killed mine with the latest s12 firmware.
                Clone safe is the only firmware that will boot without the --
                I didn't have a clone either.
                • bodyguard
                  • Jul 2011
                  • 7
                  #98
                  Thanks for your answer.
                  But where can i find a clone safe firmware?
                  • slugworth
                    • Nov 2011
                    • 1064
                    #99
                    anonymousx
                    search the forum for anonymousx
                    the 1st version was released dec 31 2011 another in feb 2012
                    • bodyguard
                      • Jul 2011
                      • 7
                      #100
                      Okay thanks. I'm gonna give it a try!
                      • bodyguard
                        • Jul 2011
                        • 7
                        #101
                        Do i need to upgrade with erom with the
                        bootloader selected? or without the bootloader?
                        • bodyguard
                          • Jul 2011
                          • 7
                          #102
                          Yes finally! With the anonymousx Feb firmware
                          Thanks mate.
                          • bodyguard
                            • Jul 2011
                            • 7
                            #103
                            But when i upload a new firmware with usb.. The same two
                            dashes appears - - .
                            So i'm back at the begin.
                            • slugworth
                              • Nov 2011
                              • 1064
                              #104
                              usb,impossible since the receiver isn't running.
                              I had to load via rs232 loader.
                              • brewejas
                                • Apr 2011
                                #105
                                Found an excellent fix. The null modem cable needs to be set up properly.
                                2 to 3
                                3 to 2
                                4 to 6 and 1
                                5 to 5
                                6 and 1 to 4
                                7 to 8
                                8 to 7
                                This should fix the issue, it did for me
