Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
I'm currently running a dm500v8 for myself, I got this as a spare for the other room. I've also got a AMG588s that needs firmware. I'm not having much luck ;-(
Hi guys,
I am new to this forum, I currently need help to recover my dead skybox F5.
Ok so here is the issue when i turn on the F5 box nothing happens it has a faint red light on the front panel when powered up and also the ethernet ports light up too, so i assume at this point the box needs a reflash with a RS232 Null modem cable.
I have tried doing a reflash with the RS232 null modem cable on my pc (windows xp) i have downloaded a few different upgrade tools from different sites. When I open the EromUpgrade icon i have the port set to COM1 as per my device manager on pc, bit rate is 115200, parity is even. Operate mode as upgrade.
So at this point when i click on browse i get 2 file options one is eromclient.abs and the other is eromclient_M3606.abs i have tried selecting either one then i click on the "include bootloader" box, when i click on NEXT i get a popup message that says "Wrong File!".
I have also tried browsing and selecting different images such as SKYBOX_F3_M3_3601HD_CMT.abs etc.. I have tried old and new versions ones again from different sites, after selecting one of these files i am able to press NEXT then it says synchronizing STBs.. please reset target! at this point i switch on the F5 box it waits then its says "Set stb memory error" click back and try again... I have tried all this above with even selecting the "data dump" option in the operate mode bit but still the same probelm.
Can someone please advise where i am going wrong?? What file do i actually select once i click on the browse button ?
sorry for the long message i thought i would get much info in there as possible... Any help or advice please? as i am pulling my hair out.. Thanks
My A3 box was stuck in a loop, it just kept counting round to L090 then restarting and doing the same again. This thread sorted it for me, pretty simple to follow, many thx darvash.
Hello got an F3 wish turn OFF while watching TV and never got it to work, no lights no display nothing, I used all the rs232 tools for this receiver and nothing, all I get is syncronize STB when I power the receiver ON with rear switch I get message DONE after that a few seconds and message STB in error status. No idea what to do, if I need to buy new memory chip or what. Thanks Turbo
There are no stupid questions, only stupids that don't ask. Author: Anonymous.
Testing SkyBox S12 FTA only
With the box powered on and the Ethernet cable in the back of the box, does the Ethernet ports light up?
I am having rebooting issues with my Skybox F5 on load up (looping.) I have reflashed it succesfully, re-programmed channel lists and also re-installed CCcam, but all scrambled channels are still scrambled. I can watch all FTA channels no problem. What i have found is it will reload after 3 attempts without the satellite f-connecter plugged in but won't load with it connected. This is what is causing the scrambled channels to remain so. Any ideas other than a single strand of outer wier touching the inner as i have redone this several times and there is no wire touching. Every idea welcome? No CCcamshows on info screen when program change.
Without the cable connected it will load, but wont descrammble in this mode.
sounds like a faulty box or lnb fault
the picture won't unscramble if the cable's not plug'd in
Easy test....take the box to a mates setup if you have one with a similar setup...try the box
if it run's ok then has to be a break in the cable or a faulty LNB
Hi all, I have read through this thread thoroughly (yep all 39 pages) to look for answer to resolving dead F5s. The problem im having is box is showing figure '8' with faint red light, have tried to go through all the different links to Erom upgrade for F3/F5/F5s which all have the same Erom Upgrade tool - STB EROM Upgrade 2.0.0c. After I go onto browse file put in a .abs file (I have tried many different ones) and press next it comes up with 'Synchronizing STBs.. Please reset target!' . At this point I have tried many methods of powering up box, putting plug in/putting power cable in and connecting at different times i.e. 2 secs, 4 secs, 7 secs but unfortunately it just wont connect. I have just reflashed a openbox S11 and have previously done a few before with no problems. So why cant I get this Skybox F5s to sync with Erom? Any advice giving greatly appreciated.
hi mate
im trying to bring my box back to life and im following your instructions but when i get to number 3
im unable to run eromupgrade.exe
my computer asks for the com port details which ive identified and filled in correctly and when i run it it keeps telling me its the wrong file
please advise me on were im going wrong
