Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
    Originally posted by maca
    Get a new PSU off the bay mate or jsut buy a better box
    can you recommend one mate.. just for watching tv dont need anything fancy
      Look here Dave http://www.digital-kaos.co.uk/forums...3-Backup-Image
        some reading in that cheers
        mate
        • Hadron
          • 2102
          #784
          The S10 & S11 had problems with bad capacitors on the power supply board. They usually show up as having a bulging top. If the tops are not perfectly flat, then they need replacing. The usuall capacitors to go bad are ones shown with the red dot.
          • bilal3715
            • Dec 2016
            #785
            My openbox v8s is stuck on LOAD so im trying to unbrick it but when I try to download the latest .abs file from the link provided, it's not opening anything so can someone help me with the issue so I can start to use my box again?
            • luisanimal67
              • Nov 2018
              #786
              mi skybox m3 hd se queda con luz roja y no sale imagen ny enciende, alguna manera de recuperarlo, me hace falta el firmware de recuperacion, pero no lo encuentro en ningun lado, alguien me puede ayudar, gracias
              • luisanimal67
                • Nov 2018
                #787
                no lo puedo descargar
                • fercm1983
                  • Oct 2019
                  not donwloading??
                  • NASSERBSSIONY
                    • Feb 2021
                    #789
                    ممتاز جدا
                    excellent
