How to install SoftCam.key into openbox
Right.. which keys are we talkin about here??
Constant.cw keys worked fine for me last time i installed them, my f/w is 14/09/11... i have not used constant.cw since december when i took out a multisat **b.. Constant.cw keys do not work for long; so as soon as they are released need to be put on ya box and enjoyed. these on here are now old so i presume they no longer work(in fact i tried the yesterday and can confirm they are outdated), As i already stated i don't need them anymore but i thought i would post them to see if other folk get any joy out of them. I Will check them in future just so folk dont complain.
Softcam.keys work perfect but there isnt much they open, C+nl zee tv, orf and a few more, keys get updated so i put them on here to share.
In the 1st post on here is a tutorial on how to install the Softcam.key into the openbox with pictures, they were took the same day as i put them on here and show sofcam connected.
These keys helped me out when i was setting up multisat as there was no point getting mutisat if i couldn't use it.
static cling
I use a static cw,maybe that's the factor.
I have seen other 3602 based firmware that you have to enable static cw by punching in a code.Don't know if s10 firmware has the same requirement.
menu 1230 enable/disable static cw didn't work in any menuComment
==============================================Hi Slugworth. What is a static cw? How do u enter it in the OB?
regardsComment
C+NL 19.2
13.0 zee tv,
orf & orf hd work, c+ work not tried rest.Attached FilesIf it isn't broke, don't try fixin it..!!!
Do I need to connect openbox to internet in order to be able to use SoftCam.Key files and constant.cw files ? Do I need to have latest firmware ? Which one ? Where can I find one ? How can I check if my openbox is genuine ? Isn't it possible to add other encryptions to openbox ? No hope in future too ? I ask a lot of questions don't I ? ; )Comment
been through all my channels on 19.2 this morning and i opened 42 channels with these keys. (I only have 600 channels stored on this sat so if there are more, then maybe more that can open)
I didn't get no joy with zee tv on 13e
I have enclosed a txt file with the channels that cleared this morning, with the download. (Ignore the channel number i put on there as your may not be on the same channel number)If it isn't broke, don't try fixin it..!!!
c+nl has changed key 06
i have +/- the same open list on astra , on hotbird some HD channels also will be open
Zee tv also is a problemAttached FilesComment
I don't get any channels with ird* and crytoworks on my openbox s10 on 19.2 with blind search. Only channels with ND (on bottom left when pressing info ) or fta are listed. What can be the problem ? The files posted here are installed with success but they alone do nothing without those chanels. : (
Someone please help me...Comment
are you selecting scan all channels and not just ftaI don't get any channels with ird* and crytoworks on my openbox s10 on 19.2 with blind search. Only channels with ND (on bottom left when pressing info ) or fta are listed. What can be the problem ? The files posted here are installed with success but they alone do nothing without those chanels. : (
Someone please help me...If it isn't broke, don't try fixin it..!!!
