offline
  • jaydog5952002
    • Dec 2011
    • 15
    offline
    all my channels is scrambled and my ccam is offline what can i do to make it active
  • darcu5
    • Jun 2011
    • 944
    did you press select to place a tick at the side of the line, then reboot.
    if you did make sure you have network settings and are set to dhcp
    if above is done try contacting whoever you get your line off or try someone else
    If it isn't broke, don't try fixin it..!!!
    • jaydog5952002
      • Dec 2011
      • 15
      what you mean by tick at the side of the line and my dhcp is set on
      • darcu5
        • Jun 2011
        • 944
        go to cccam and select manage config files - then cccam.cfg it select the cccam and it will place a tick at the end of it, then exit and reboot
        • darcu5
          • Jun 2011
          • 944
          if it is already connected, then the problem may not be at your end; so get a test of someone else
          • jaydog5952002
            • Dec 2011
            • 15
            i tried that it didnt work does it matter if i set mgcamd or static ip
