Openbox Channel List inc Asians Updated Regularly
  • RP3X
    • 48
    #196
    Perfect thread for me to ask a general question
    I have noticed english subtitles has never worked on Asian channels on 28e, it appears on screen and vanishes very fast however it works fine on english channels just fine.
    Has anyone found a firmware that is working for Asian channels with english subtitles?
    The strange issue is french works fine....
    • antwalk9
      • Jan 2013
      will this work on f5 mate?
      • mast
        • Nov 2010
        • 1027
        #198
        Hi
        Bit late but yes it will as Ive just put it on an F5 recently with no issues other than renaming favs.
        Regards
        • mast
          • Nov 2010
          • 1027
          #199
          Originally posted by tazg101
          Hi any chance hour next update could have syfyHD , thanks
          Hi
          Bit late but has now been added. List has been updated to todays date with some minor updates.
          Regards
          • asifanas
            • Feb 2013
            can u still acess adult channels
            • mezzyg
              • Apr 2010
              • 158
              #201
              Yes they are there but not in the favs,
              Sent from my Nexus 4 using Tapatalk 2
              • toucarrie
                • Feb 2013
                Hi Im new to this where can i get a Cccam.cfg file thanks
                • slackman
                  • Feb 2013
                  will this work on m5 mate?
                  • cramman1986
                    • Feb 2013
                    updated channel list
                    hi can anyone direct me to an up to date channel list for the F3 thanks
                      Well you found dk im sure a bit of searching you'll find what you wish for
                      • paul93
                        • 50
                        #206
                        adult channels
                        how to add adult channels on skybox f3.
                        • paul93
                          • 50
                          #207
                          Channel list
                          as explained here i did put that file to get bouquet and channels but channels are back but not the bouquet where i can divide the channels like music entertainment sport etc what i am doing wrong plz help and want to add adult channels as well.
                          • mast
                            • Nov 2010
                            • 1027
                            #208
                            Hi
                            It is up to date.
                            Regards
                            • mast
                              • Nov 2010
                              • 1027
                              #209
                              Hi
                              You will have to do as below.
                              Adding Bouquet to Favs
                              To clear the existing name (fav 9, 10 or whatever) press the red delete button to remove the letters till the screen is clear.
                              Then use the up/down/left/right arrow keys to select a letter. If you need a capital letter press the yellow button once to change from lower case to higher case and press yellow again to go back.
                              When you have entered the name you want to keep press the blue button to save.
                              Adding Channels to F3 F5 M5
                              Menu > Edit Channel > ok > Favourites Edit > Red Button to go to All Satellite > Press
                              Fav Button and choose fav bouquet you want to add to.
                              So left pane will have All Satellite list and right pane will have Fav Bouquet list that
                              you want to add to.
                              In Left pane scroll to channels you want to add and Ok so it has tick, you can choose
                              multiple channels.
                              Once you have selected all channels you want to add to this Fav Bouquet > Right arrow to
                              go to Middle Window > Press + button to add channels to Fav Bouquets > Right arrow to go
                              into Fav bouquet and check that the channels have been added > exit and ok to save and
                              return to tv screen.
                              Regards
                              • mueez1
                                • Feb 2013
                                How many channels are there?
