Openbox s 10 hd
  • nilefish
    • 13
    Openbox s 10 hd
    I have just got my box and I was very exited. but right from the start there are few issues.
    1- The box came with only 3 sat installed and I managed to add the sat of my choice but no transponders .. I cannot imagined adding 100s of transponder manually
    2-The box keep rebooting when I try to set up the motor
    Any help will be much appreciated.
    Regards.
    TM 3300 / DB 500S / Triax 110 / Sat 0.8W-42E
  • Manic01
    • 5117
    Download a channel list.
    • nilefish
      • 13
      Thanks I have downloaded the channel list every thing is fine.
      I have updated the flash memory, I got better menu and signal quality but its the same with the motor setting. I'm on Astra 28 E and the receiver keeps rebooting whenever I try to move the dish
      I'm using Triax TD 110 with 1.2 Motor, I have used it with Several receivers before , DM 500S , Technomate , Spiderbox
      I'm not sure if I'm doing something wrong
      Regards.
      • nilefish
        • 13
        Forgot to say
        In the Antenna setup page I have DiSEqC1.0 and 1.1 disable and 22K set as Auto
        Motor type 1.2
        LNB Freq Universal ( 9750-10600)
        Thanks in advance
        • tonynw
          • Nov 2011
          • 147
          re boot
          put in the box your co ordinates and use usals it should then work ok.
          tonynw
          • nilefish
            • 13
            I tried that ..did not work .. the box keep rebooting
            • nilefish
              • 13
              I managed to move the dish to Astra 19.2 , got all the channels , when try to move it back to Astra 28.2 , the box keep rebooting I had to disconnect the cable from the receiver and have it permanently on Astra 19.2
              I tired different firmware still no luck any ideas?
              • tonynw
                • Nov 2011
                • 147
                Best idea send it back to where you bought it from save loads of hassle
                tonynw
                • nilefish
                  • 13
                  Thanks I have done that and I will get the refund soon, but is this a general problem with open box ? I'm wondering if buy another box might be the same
                  Please advice
