Hi all. i am nem to this forum and am hoping someone can help me,i have an openbox s10 and it has recently got the v format nightmare. I have tried everything that has been suggested by various searching, but nothing works it just wont lock back on 1080i-60 its stuck on pal, i have also just tried a phono/scart lead and still nothing, even thied the blind scan you know, menu r - ran all that still nothing, is there a software or firmware that will maybe help reset or eradicate this problem. Tahnks in anticipation and fingers crossed . Taggy
head about to explode
1. Turn off the unit, then reboot it using the back switch.
2. Position yourself in front of the S10 so you know it is getting a good signal from the remote. Then press the following sequence carefully on the remote:
MENU > RIGHT ARROW > RIGHT ARROW > OK > DOWN ARROW > OK
3. You are now in the video resolution settings. Press the LEFT ARROW key and wait 5 seconds for the resolution to change. If no picture after 5 seconds, hit LEFT ARROW again, wait 5 seconds, repeat until you hit a compatible mode.Comment
