OPENBOX S10 NO CLONE 05/01/2012 Beta firmware
  • Shady
    Shite Link King
    • Dec 2010
    • 6404
    Found this elsewhere, its beta and dont know if its clone safe.
    not tried it as mrs watching soap shite and then im watching footy
    edit:
    also find attached s9 beta firmware
  • mlatif
    Is this firmware offical
    • Manic01
      • 5117
      Anonymous fw is clone safe.
      • pspmixer
        • Jun 2009
        • 750
        edit:
        would this s9 fw work on original's as it works great on my clone is very stable
        • darcu5
          • Jun 2011
          • 944
          Fixed by anonymouSX 5 jan 2012
          fixed Timebomb kill clone
          Id detection fixed
          Reboot probleme fixed
          cc**m lag freeze Fixed
          Standby Freeze issue Fixed
          Power on Message on Display Changed
          If it isn't broke, don't try fixin it..!!!
          • ohmygod99
            • Jan 2012
            Thank you....
            • Shady
              Shite Link King
              • Dec 2010
              • 6404
              I am running the s10 fw above on my original box, comes ready set up with euro sats, start up background now says skybox.. so far so good
              • rostov
                • Jan 2012
                thank you you are great
                • kman999
                  • Jun 2011
                  • 43
                  I tried this on my s11 and found the front display issues has been resolved but randomly my remote locked, maybe its a s11???
                  • mrfarnhigh
                    • Jan 2012
                    • 15
                    why not making a better and bigger (using usb) and more quality firmware if the code is hacked. 4mb firmware cann't be as good as dreamboxes one.
                    this thing has enough ram, if i'm not wrong 1g and 400mhz cpu and I guess with using USB port and a flash memory, a team could make a better firmware like for other linux receivers
                    • slugworth
                      • Nov 2011
                      • 1064
                      1/2 size
                      Originally posted by mrfarnhigh
                      4mb firmware can't be as good as dreamboxes one.
                      If you look at the .abs you will see they are only using about 1/2 the flash now.
                      The receiver isn't linux,it uses ali tds2 rtos
                      Mainboard: 396MHz MIPS CPU, 128MB DDR400 RAM, Memory Clock 198Mhz, 4MB Serial Flash, Single Tuner, DVB-S2 demodulator
                      • ravindranchenna
                        • Jan 2012
                        Where can one get a user manual of skybox S11
                        • Manic01
                          • 5117
                          Use search or google functions
                          • mrfarnhigh
                            • Jan 2012
                            • 15
                            mb you have clone?
                            that's what I have:
                            Specification
                            *Chipset and Memory:
                            CPU: 396MHz
                            Flash: 4Mbytes
                            RAM: DDR2-1Gbit
                            and the firmware is 4mb, where is the half?
                            also I guess it doesn't metter if it's linux or not currently, on those cpu you can find linux receivers too, so I guess it's solved, why not to support the idea? it will only make this receiver better
                            • slugworth
                              • Nov 2011
                              • 1064
                              org
                              mb you have clone?
                              that's what I have:
                              Specification
                              CPU: 396MHz
                              Flash: 4Mbytes
                              RAM: DDR2-1Gbit
                              also I guess it doesn't matter if it's linux or not currently, on those cpu you can find linux receivers too, so I guess it's solved, why not to support the idea? it will only make this receiver better
                              page 3 of the users manual says 128mb ddr400 ram.
                              not a clone.
                              the sdram.ini file of the rs232 loader is set for 128mb ram.
                              1/2 the flash is code,the other 1/2 is FF's so only 1/2 is being used.A moot point since most code is usually transferred and runs from ram anyway.
