right guys trying to flash an s10 for a mate no display nothing so am using the eprom updater and tryed several diff firmware but nothing the updater just sits at synchronizing stbs please reset targets for ages anyone any ideas cheersssssssssss
bricked s10
Tags: None
doesnt even say on then when i load the eprom updater then hit next it just sits for ages when i press cancell after ages it say are you sure downloading but it goes on forever think it for the bin
HAD THE PARTY LOLComment
off
receiver has to be off when you hit connect on loader,then you turn the receiver on.
Make sure you are using the correct type rs232 cable.
It must be null modem not straight thru.Comment
the receiver is set to off mate when i hit next then turn it on and its a null modem cable cheers
I have had the Exact same problem. Replace all the capasitors in the power supply.
You can run a hair drier over the caps to see if you can identify the ones that are likely to be wrong.get on your or off your box, with a bong!
At least once a month,
You only live once!Comment
its not the power supply tested it with meter theres power at the board its defo corrupt firmware ill keep trying to flash it cheers
back in the saddle again
try this one on stubborn receivers.
Attached FilesComment
DW190
