S10 Lockup/Freeze ??
  • Jack Jumpin
    • Sep 2009
    • 31
    Over the last week or my S10 has been freezeing/locking up for no apparent reason..
    I was watching the Liverpool game today on ITV which is FTV and it just lockup with a picture on the screen, remote dead and box buttons frozen so had to reboot with switch at the back. I wouldn't say it does in constantly but its been fine for 4 months.. any ideas ??
    Cheers
    JJ
  • slugworth
    • Nov 2011
    • 1064
    heat
    overheating maybe?
    newer firmware runs hotter.
    • dirtydonki
      • 37
      Although the box does not appear to get hot it is definately down to heat.
      I had to move mine into the open air but it still happens after a while.
      Might be worth fitting a fan to it.
      The other option is to revert to the old firmware but that doesn't seem to have any way of playing back rmovies, recorded or otherwise.
      It's not a bad little box but it is a cheapy and as such you get what you pay for.
      Can't wait to be able to afford something that actually works & is fully configurable.
      __________________________________________________ ______
      SKY TV
      Never before in history has so much been paid by so many for so little.
      • molveees
        • Nov 2011
        • 4
        Cheers
        JJ
        Most likely the networking causing the freeze. I have found with my box that it reboots every now & then (happens everytime when using cccam). if i unplug the network cable & stick to freeview only then the problem disappears completely. I don't think theres much depth in "new FW running hotter". I have no evidence of that.
        • Jack Jumpin
          • Sep 2009
          • 31
          Cracked it, it was due to having a sly card in the box, I was trying to use it for UK FTV channels, as my CS don't have them. Now the card is removed no issues at all...
          Cheers
          JJ
          • SAndy777
            • Feb 2012
            capacitors in the tuner 16V 100mkf change 100mkf 25V capacitors from the picture and enjoy the normal operation of the receiver (I'm stuck 100mkf 35V all ok).
