openbox s11 no signal
  • asad5150
    • Oct 2008
    • 185
    iv got a skybox s11most channels work but some channels say no signal they are manily hd ones. is ther any fix??
  • DW190
    Could be dish slightly out or possible weak tuner. You could try a satellite amp.
    • asad5150
      • Oct 2008
      • 185
      wats a sat amp?
      • eattheliving
        • 331
        Satellite amplifier signal booster Sky amp sat lmb lnb | eBay
        hope this helps mate
        • fylton03
          • 59
          switch lnb settings to universal 9750-10600
          hope this helps
          • Manic01
            • 5117
            These are the universal settings needed.
            9750 / 10600
            • asad5150
              • Oct 2008
              • 185
              The signal bar says signal is less than 10% so should the amp boost make it work??
              • asad5150
                • Oct 2008
                • 185
                Sky sports 1,2,4,news in hd work fine but sky aports 3 and espn dnt work they show no signal
                • eattheliving
                  • 331
                  do you have any other box connected to the LNB/Dish which is feeding your S11?
                  if yes then the in line amp should help. but try the LNB settings first tho.
                  • asad5150
                    • Oct 2008
                    • 185
                    no other box connected and iv done the settings but no luck. also noticed that boomerang doesnt work but it used to work wiv my dreambox
                    • TheBoss22
                      • Mar 2012
                      • 5
                      Hi mate, I had same issue and bought a little box thing off ebay that fixed it. can't remember exactly what its called but was something like 'openbox no signal fixer' or something like that. hope that helps! I know how annoying it was to not have all the channels
                      • TheBoss22
                        • Mar 2012
                        • 5
                        found the link actually - No Signal Fix for Openbox s10 s11 Skybox s12 V Polarized channel selection | eBay
                        (apologies to the mods if it's against the rules to post links etc, please just remove it if so )
                        • DW190
                          I seem to recollect seeing something like this before and it appeared to be a very expensive sat amp.
                          Are you by any chance the seller of that gadget?
                          • DW190
                            I'd say you came here to push that link.
                            • TheBoss22
                              • Mar 2012
                              • 5
                              Sorry guys but I'm not selling these, just wanted to let you know that it helped me. I have read the forums for a while and got a lot of help so thot it was time I registered and gave something back to the community.
