AJ's Sky UK Channel List **Discussion** Thread
  • crc365
    • Apr 2013
    • 6
    #2401
    Originally posted by Grover2000
    Can you please send me the latest HD without adult list with channels updated?
    Grover
    List is here
    • bijan
      • 58
      #2402
      Hi I've updated the channel list but Star Gold is not working can any one help please?
        Any 1 know frequency on sports primetime ch??
        • jackellis20
          • Dec 2013
          • 12
          #2404
          Just updated to the newset channel list, thankyou great work.
          One thing though, before I updated when I pressed "OK" on SS1 it would bring all the channels up which are in sport in a big square box which meant swtiching from SS1 to say Premier Sports was qucik and easy. After I have updated when I press "OK" now it opens up like the "FAV" menu so I have to scroll down to move to a channel in the same sector.
          Not sure if that make sense, its not a major problem, preffered it the way it was that all. Any ideas?
          • DW190
            • May 2012
            • 1263
            #2405
            Try the King of Sat
            Astra 1N / Astra 2A / Astra 2D / Astra 2F / Eutelsat 28A / Eutelsat 28B (28.2?E) - All transmissions - frequencies - KingOfSat
            Frequency is there but nowts coming on it. Showing Invalid.
            • bijan
              • 58
              #2406
              Does star gold work guys??
              • spiker
                • Apr 2013
                I tried adding the latest channel list 14/12/2013 but the BT sports channels are totally missing, any idea why?
                • jacquesy90
                  • Dec 2013
                  • 92
                  #2408
                  My f5s is fresh out the box and has the default sats in the sat list? i think... anyway once ive installed this list will it update the sat list with the "skyuk sat"???
                  Confused coz ive gt lots of sats in my list and the only one which is set to 28.2 is eutelsat 28a
                  ive seen i need to be on an astra sat but ther not 28.2...... heads chocker here.
                  in a nutshell will this channel list update my sat list so its not as confusing? thanks!
                  • P&D
                    • May 2010
                    • 2684
                    #2409
                    If you have a fixed dish pointing at Sly.....28.2E yes its correct
                    if the box has pre-loaded sat's.....when you goto fav's does it show all the channels ???
                    if it show's all the channels ssp1... bt sports...& so on no need to add a channel list its already got one installed
                    but might need updating
                    If your new to this & have not owned a box before just going off the questions you have already asked on here.....???
                    Then i'm going to guess your next question might be...only a guess by the way don't intend to insult
                    All the channels with the $ are scrambled..........That's where you need to use Google not DK
                    • joe516
                      • 1000
                      #2410
                      12.640 V, 22.000, 5/6
                      Primetime has ceased broadcasting from Sky platform.
                      information given is to be used for educational purposes only
                      Don't Forget To Say Thanks If You Like My Post
                      IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
                      If It Ain't Broke Don't Fix It
                      • jacquesy90
                        • Dec 2013
                        • 92
                        #2411
                        Noo not in faves I done a scan and all the channels are mixed up, it has bt sport and stuff tho. I take it that's wer ajs list will come in? Just confused by the the diff sats n which one should I be on.. as ive scanned a few and the same channels come up. And no i understand about the scrambled channels.
                        • P&D
                          • May 2010
                          • 2684
                          #2412
                          If you have done a scan then you should have all the channels ...No need for Aj's channel list....
                          If the channels are all mixed up (not sure what you mean) unless you mean not the same as $ly listing's
                          If you have a fixed dish (one that does not move) then it does not matter what sat you scan you will always get the same result..
                          As for the scrambled $ channels .....scanning the sat's or adding Aj's list will not open therm so you can watch them.....the box needs an extra bit to do this....& thats the part we cannot help with
                          • jacquesy90
                            • Dec 2013
                            • 92
                            #2413
                            Yes that's what I mean not in order, so installing ajs channel list will order them in the sky format yes?
                            Yes it must be a fixed dish then that's why I was confused as was getting same results on all sats.
                            And a I said before, I undetand about scrambled channels.
                            • MexicanSeafood
                              • Dec 2013
                              #2414
                              Seems like your in the same boat as me. Been setting up my Skybox today and found all the channel on eutelsat which I believe is Sky. Thing is all the channels don't seem to be in any order and some show multiple times. If I install Aj's channel list will it put my channels in order, eg. all movies together and all music channels together etc. At the Mo they seem to be chucked in any order.
                              • jacquesy90
                                • Dec 2013
                                • 92
                                #2415
                                Yes mate exactly.
                                I tried to install AJ's. couldn't get it to work, so i installed sattvs instead, guessing there pretty much the same. Everythings now in order plus says "skyuk" in the sat list!
                                Make sure you delete all channels before the update and possibly factory reset.
